No its uploading right now I forgot to upload it last night
I assume that it is a hybrid of AOKP 4.1 and stock?
Not this ROM but my new one will kind of be like that, and droid-man sorry Its still uploading the new version, be patient![]()
Hey guys my new ROM will be based on cm10 now because aokp is laggy and I did speed it up pretty good but it killed the battery fast when adding in all of the performance tweaks, so I'm using cm10 now cause its so much smoother, and about this ROM I'm still trying to fix the Bluetooth I'll do some testing tonight and see what I can do
Maybe I can integrate or merge aokp control into cm I'll ask some dev at xda, I've seen lots of devs merge aokp and cm and pa like the PAC Man ROMs, well see
I really don't know what is possible, but since no one had responded I am trying to help you find out with the mighty powers of google lol.
To start, the admins where say no? I looked on flashitnow.com and the verizon lg spectrum is a supported device...
Thanks! The admins of flashitnow said that. I think I'll simply try and see if it works. I know the call and text will but want at least 1X else it could be almost pointless :/
A better question would be this: Is there a way to turn off 4G but not 3G? I know there are some apps in the market but none for spectrum.
Hey,
First time posting. I've flashed several ROMs in the past and been fine. However when I flashed your ICY-FUSION-R2.0-FINAL.zip (the link from first post) I had problems. (this was the only ROM I could find, your sourceforge page had nothing on it at all).
I followed the directions correctly (not my first time doing this). The install looked good, however when the phone booted it jumped into a "Windows Phone" splash screen, which I thought was odd... Then it came on and had 4 different home screen apps, at least one of which was all in Chinese.
At this point I was going to go roll back to my previous version (which I had backed up with nandroid). However I was silly and had moved the backup off my phone onto my PC.
No big deal, just open SD card in mass storage mode and copy the recovery file over, right?
Nope, with your ROM my computer no longer recognized the phone so I can't connect to it. I restarted my PC, uninstalled and reinstalled the LG USB Drivers, restarted PC, and still doesn't work. The device appears in device manager with the warning symbol saying it can't find the drivers. (NOTE: I never had this issue with stock rom or others).
So, since my cat recently destroyed my microSD adapter I'll be running to MicroCenter in a minute to get a new one so I can manually copy my recovery image onto it and then re-flash that.
Not hating on you or your ROM (I think something went wrong or somehow the link is bad and I got a bad file) because my experience differs greatly from what I see other users commenting in this thread. But if something is amiss I thought you should know.
i've said it twice, and i'll say it again...USE AIRDROID!
I havent needed to hook my phone to my pc in 2 weeks since I started uisng airdroid.
Yes these are the only apps I use now! I threw away my USB cable a long time ago! I actually use wifi explorer pro
I'm going to check that app out. Thanks.
Though airdroid has worked flawless for me. And I love how it lets you message, and tells you your battery level
I use Samba Fileshare, though it does act a bit wonky on this ROM. Just slow to start up, that's all. I can live with it.
I do find that transferring files over wifi is much slower than over USB.
Any recommendations on a good wifi "file syncing" app? I was using Syncness, but it hasn't been updated in over a year and doesn't work in ICS.
