yeah im staying on ics roms now, cm10 did not like gaming on my spec, very laggy, so until gaming becomes awesome on cm10, which tdm will do it im sure of, im staying on ics roms
How is your latest version looking anyway?going great, removed a bunch of stuff that just slowed the rom down, and added some nice features, and also added some tweaks to speed it up a little bit, will be uploading new version very soon
Yeah I hate that boot, and I might not release an update today, I feel like crap, fever, headache, so will take a break for a few days
and i forgot to add your kernel, i was having problems actually it wouldnt get past the lg logo
well it works when i just flash it seperate, but when i integrate it into the rom, i put the new modules in and the boot.img, and i also set the permissions in the script for the modules, but it doesnt boot up, its strange....
set_perm_recursive(0, 0, 0755, 0644, "/system/lib/modules");
Hmm, I'll take a look into it while I have some time tonight. I'll post back with my findings.
EDIT:
So, I looked through your update script. I think you need to set the perms on the modules specifically. I didn't find a line that did that in it. Add this in to the set_perm area and see how it goes:Code:set_perm_recursive(0, 0, 0755, 0644, "/system/lib/modules");
Well I did sets those one other times when I tried adding your kernel in but maybe I did something wrong I'll try it again
need to remember not to do that with Azoller. Love the constant updates
thanks!Hmm I was getting my phone set up for a long term driverneed to remember not to do that with Azoller. Love the constant updates
thanks!
I flashed that kernel right after flashing this ROM and everything was fine until the WiFi here went down and I had to start playing Peek a Boo with the data connection.
Not sure if the filthy flash (wipe nothing) of the kernel was the problem.
I went right back to the BionX nandroid that I made just before I flashed and the data issue stayed.
I restored a BareBones nandroid and POW data came right back.
I restored the ICY 2.5 I made moments ago and wonky data.
I might try to flash clean without the kernel and see.
Sometimes the OC stays around 1.6 and the CPU temp hits 145' F.
No matter what I set System Tuner at, even the set at boot, it always ramps up.
The first time I tried to flash bionx_prealpha, I did a dirty wipe (cache and dalvik only) and i got a hung boot (the screen was dim with nothing on it).
I'm sure it was something I did or did not do that was the cause.
I checked the MD5 on the sd card.
I wish L (Lame) G (Gonad) would post the REAL source code for the ICS kernel...
I hope the North kicks their asses for this.
Well in a nice way any way..![]()
