Sounds like adb isn't enabled by default. It probably just needs to be set in the default.prop file.
Yea, about that,
I looked through the build prop for a way to disable this pesky popup for "Global Roaming".
I found a few typos like "system prpo for sound exeption".
I guess if the xml file is synced with it, it could be "BOOBS" or something.
It is that way in every ROM so far....
I corrected the spelling in just the build prop and got a hung boot...
I can't wait to see the finished product! Thanks azoller and Brian, and ortrigger for your kernel!
