Root [ROM][July14] Icy Fusion V5.0 | Smooth | Tweaked | Themed | Battery
I JUST installed this ROM and it hasn't progressed after reboot on the "S" symbol...anything???? help???
Pull the battery, then reboot. If it does it again, then try flashing an older version, boot it up, reboot to recovery and dirty flash over it.
go back to recovery reflash the rom then wipe both caches after the rom flashed and also go to advanced fix permissions after you flash it then reboot
Can i use this mod even though i have already updated to ICS? My carrier is verizon and i have android 4.0.4 VS920ZV7 i just rooted my phone and have no idea how to add a mod nor do i know of any mods for my phone. friends tell me that LG Spectrum has low developer support. PLEASE HELP
There is an all things root guide that has links the everything you need to know. Do some searching and reading and you'll be rooted in no time.
did you recieve my PM?
downloaded v3.0...still doesn't get passed the "s" screen...anyone care to PM me to try and solve this? wanted to run this ROM cause CM10 doesn't let me play games on my phone for more than 10 mins...i loved that ROM other than that, so wanted to try this one out...again, any help is greatfukL!
This ROM is working great for me.
I just wiped the cache and dalvik and flashed from ICY 3.0.
I did fix permissions and agreed to that last little prompt.
Sometimes when my device hangs, I press and hold the power button until it shuts off.
Pull the battery out, both cards and hold the power button for a 10 count.
Put it all back together and press and hold the power and volume down until the reset prompt shows then tap power twice and re flash.
Sometimes that fixes the Boot Hang.
Also check the MD5 on the card after download or transfer.
v2.9 worked...just no data is able to work..no calls, no texts..
I got LTE On Off from the market and found that when I flashed 3.1 the setting was set to EVDO Only.
After changing it to CDMA (Auto PRL) it works great out here.
I won't know about LTE until later when I drive 21 miles to the city...
you obv have the spectrum 1 right?? can you PM me in specific details on how you got 3.0 to work? (im kinda new at this)
i'm trying to do this, but i'm still confused...i can't or don;t know how to reflash??
You should restore the nandroid of 2.9, install LTE On Off from the market and get your signal to work first, some times it's better to set it to LTE/CDMA/EVDO just before you flash.
Then check the MD5 code of ICY-3.1 when you get it on your SD Card.
I use a card reader on my laptop.
Just remember to always wipe at least cache and dalvik when flashing an updated ROM of the same base.
Although one time when I came from CM 10, I had to call VZW to get my data reset. Something about authentication getting corrupted.
If your data works when restoring another nandroid then that might not be your problem...
