i'm trying to do this, but i'm still confused...i can't or don;t know how to reflash??
Do you have Clockwork Mod installed?
You should restore the nandroid of 2.9, install LTE On Off from the market and get your signal to work first, some times it's better to set it to LTE/CDMA/EVDO just before you flash.
Then check the MD5 code of ICY-3.1 when you get it on your SD Card.
I use a card reader on my laptop.
Just remember to always wipe at least cache and dalvik when flashing an updated ROM of the same base.
Although one time when I came from CM 10, I had to call VZW to get my data reset. Something about authentication getting corrupted.
If your data works when restoring another nandroid then that might not be your problem...
Can i use this mod even though i have already updated to ICS? My carrier is verizon and i have android 4.0.4 VS920ZV7 i just rooted my phone and have no idea how to add a mod nor do i know of any mods for my phone. friends tell me that LG Spectrum has low developer support. PLEASE HELP
what's the md5 code?? or where is that found in teh zip file? i'm trying to change roms from CM10/AOKP to this one because the cm10/aokp one won't let me play a game for more than 10 mins before it restarts on me
What version of CM10 did you have? If you don't need GPS I would recommend CM10.1, by far the smoothest running ROM we've had so far. I find the MD5 using ES File Explorer. Long press the file, Properties, show Checksum, MD5, calculate.
i just thought it was cm10? never said it had an update on goo. i like my gps lol but i like to game too. and that's why it was pissing me off cause it'd reboot on me all the time playing a game
not sure what i did but, it seems i dont need to reboot to get usb mass storage to work...
now uploading version 3.2, and maybe somewhere in this update i modified some file that fixes the usb thing, well see how it goes
yep i made sure i had that in there![]()
version 3.2 us uploaded
changes
VERSION 3.2 (2/15/2013)
-Resized Battery Icons To Normal Size (Didnt Seem To Get Bigger..)
-More Icon Themeing For Statusbar and Pulldown Icons
-Updated XenoAmp to V161
-Updated To Ortriggers Latest Kernel Alpha V1.2.1
-Updated TricksterMod App
-New Bootanimation Nexus 7 Boot Big "X" (The X Shows Up Then Goes Away Weird..)
-New Build.prop tweaks
-Fixed Build.prop tweaks
-Removed 3G Tweaks, Made 4G Worse
-Fixed Updater Script for Less Hung Boots (Thanks Ortrigger)
-Removed Emoze App, Stock Email App Works For Exchange Now
-Other Changes And Performance Tweaks
How long should the screen stay black? coming from aokp 41.
Did you do a clean flash?
I would love to try out your new rooms, but I cannot seem to clean install from cm10... Every single time it just hangs at boot. I tried installing an old version (2.9) and then going to 3.1 and I had a bunch of force closes and every amok showed up on MUDs card...really weird. Could just be my phone but I don't know. I am going to try and flash to slim droid and then go from slim droid to your 3.2... Thanks for all your hard work!
