Root [Rom/Kernel]AWEsome Rom[V1.6]
dragonhart6505
Android Expert
*****YOUR WARRANTY IS NOW VOID!
By installing this rom you are accepting any and all responsibility pertaining to bricks, crashes and failure to follow directions! It is YOUR DEVICE! If you are uncomfortable with modifying your phone, LEAVE NOW!*****
Your phone is about to be AWEsome!
This is a custom rom I have been working on for a while. It is a WORK-IN-PROGRESS though there shouldn't be too many (if any) bugs. Updates are expected.
This is basically a stripped stock rom. Anything ZTE related has been removed and replaced with alternatives. Nothing fancy (and I dont plan to make it fancy), just enjoy its speed and reliability.
Features:
  • Based off Stock 4.1.2
  • Nexus Boot Animation
  • Rooted
  • Fully Deodexed/Debloated/Zipaligned
  • New O/C Kernel by Spock1104!!
  • Tweaked Settings Menu *DONE-ISH*
  • Reboot Menu *TBA*
  • Fast and Smooth
  • Activatable!
Included Apps:
  • KitKat Launcher (Replaces Stock Launcher)
  • TricksterMod (For Setting Kernel Values)
  • Titanium Backup
  • Busybox On Rails (Install Busybox applets, needed for Trickstermod)
  • Cyanogen Calculator (Replaces Stock Calc)
  • Omni Notes
  • Superuser
  • Root Explorer (Replaces Filer)
  • Terminal Emulator
  • Wifi Tether *Fixing*
Some apps may have updates, even though I tried to add the latest versions.
Removed:
  • Virgin Mobile Apps
  • ZTE/Firmware Updates (Won't Install Anyway)
  • Stock Browser (Chrome is Default)
  • Google Play Apps (Books, Movies, YouTube, Games)
  • TouchPal/Swype Keyboards (Request to Include?)
  • Live Wallpapers (Request to Include?)
TO DO:
  • Customize Settings Menu *DONE-ISH*
  • Fix PRL/Profile Updating *DONE*
  • Fix Wifi Tether App (Stated Above)
  • Add Reboot Menu (Stated Above)
  • AOSP Lockscreen (Coming in V2)
  • Other Stuff I Find Useful/Broken (Make Requests, I'll See What I Can Do)
Instructions:
  • Download Rom *HERE* (Mediafire link, because d-host hates me)
  • Install ClockworkMod Recovery Easy Method Here
  • Reboot to CWM - Volume Down/Power Button (Vol+/- to Navigate, Power to Select)
  • Wipe System/Data/Cache/Dalvik-Cache
  • Install Rom from SDCard
  • Wipe Cache/Dalvik-Cache AGAIN
  • Select Reboot ***HIT NO WHEN PROMPTED***
CHANGELOG:
Code:
Version 1.6
-New update-binary (thanks brittnearl)
Version 1.5
-Fourth Release
--Added spocks kernel
--Updated apps
--Changed DPI to 190 (looks sleaker to me, change at your will)
Version 1.2
-Third Release
--Replaced Overclock Kernel with Stock Kernel
--Replaced WiFi modules with stock modules
Version 1.1
-Second Release
--Replaced Apex with KitKat Launcher (from Play Store, NOT OFFICIAL GPL)
--Replaced Android Tuner with TricksterMod (apparently I'm the only one on earth who knows how to/likes to AT) :-P
--Added Busybox on Rails (INSTALL APPLETS BEFORE USING TRICKSTERMOD!)
--Added Titanium Backup
--Reworked updater-script (hopefully fixes reboots...if not, will rerelease)
--Modded Settings app a little (System Updates is now Network Updates, Activate this Device is now Activation, removed Connections Optimizer from Mobile Networks menu)
--build.prop edit (SW Version now says AWEsome) :-)
Version 1.0
-Initial release
--Added rbheromax/cooldudezach's overclock kernel
--Added cooldudezach's wifi fix
--Fixed root permissions
--Removed Wifi Tether app *FIXING*
--Added Root Explorer
Special Thanks for Their Hard Work:
rbheromax
cooldudezach
junkie2100
Spz0
_1mous3_
And THANK YOU for downloading! :D :D :D
---Please report any issues you may find. Requests for features will be taken note of and I will do what I can to implement them---
dragongart6505, is the oc kernel in this rom fixed for the devices that end up boot looped?
Thank you for your hard work, much appreciated! Definitely looking forward to trying this when its released!
Indeed it is (thanks cooldudezach). Hence the *WORKING* for all awe phones.
It is very much stable, however we are still tweaking it a bit so I believe it is considered [Beta]. No worries though, its working great on my personal device and my g/f's, hers having experienced the bootloop problem.
what about aosp lock screen?? also nova launcher uses less resources
Apex is actually alot smoother and it doesnt take too much resources. I am trying to get the lockscreen implemented, but its ALOT of work. Ill add it to the list here though. I can put xposed lockscreen in if requested, but id like to keep xposed framework an optional thing
Spz0 figured it out for the ZTE Source, so come on IRC and he'll help. He says its easy to do :D
rofl. you kidding? took me a days worth of digging and snooping around the framework to accomplish for the hera! o.@
Im working on it for the awe and warp atm. I'll be releasing a separate flashable zip for all 3 8930 devices when its complete. Again, I'm a new dad so it'll get done when it gets done :-P
Just flashed the ROM. Thanks for all the devs hard work on this:) Is it initially slow too boot right after flashing? Thanks again guys! Can't wait to see what Roms may become available for this phone:)
I got 10 weeks til mine comes so I feel you >_< anyway, when you get the zip ready I'll add it directly into my from if thats ok with you.
Also, anybody else randomly get their internet turned back on even though its been turned off for 3 days and you have received the past due notice from Virgin? Lol, so silly but hey free internet so I ain't complaining ^_^
I'm stuck in a consistent bootloop. I've wiped everything so many times and reflashed the ROM. Same problem: ( not sure how to fix it.
I've even redownloaded the link 3 times from 3 different browsers. So idk.
"Never mind. Got it. ROM is niiiice Thanks again!"
So what is this? Does it work for you or not?
This really should be working for everyone. I and the team have tested the kernel extensively and have found no issues. Did you clear the cache and dalvik-cache after flashing the rom?
Well it worked for about an hour. And now it boots up, goes to the lock screen, and then reboots, and its been doing it for 45 minutes. Sucks cuz I love the ROM.
