INTRO
Initially I was going to make a fresh stock ROM from firmware G then I realized apps were outdated so I added updated Apps. Then I realized LG Motion Launcher is too simple so I changed that to a newer version.
Eventually I kept going and going and changed whole bunch of things. I also changed sounds, keyboard and wallpapers. Instead of having simple stock ROM I ended up having updated Motion year 2014 version
It's about time, give your good ol motion some new dress (IF you still have Motion lol
ROM FEATURES
Made from Firmware G phone from the scratch
Zipaligned, Deodexed, Debloated
Loki-patched Insecure Kernel
Updated LG Home Launcher with
7 additional themes
LG G2 Keyboard with
3 additional themes
80+ New LG G2 Ringtones, Notification Sounds, UI Sounds
Updated apps including the most recent Google Playstore and Chrome (as of 07/31/2014)
Fast, snappy, light weight, battery saving, new looks and additional themes
SCREEN SHOTS
DOWNLOAD
Current Version 1a
https://drive.google.com/file/d/0B69dMfqyU4n9bEcwNjlEWU9oa3M/edit?usp=sharing
MD5 Sum :: 227357d82dbccb59262648a670131d86
INSTALL
I recommend you to have version G installed. It may work well with other versions but I am not sure..
1. Download the ZIP file then copy it on the root of external-SD card.
2. Go to CWM by clicking Reboot Recovery @ 2nd-init Recovery app
3. Switch to the External SD mode by clicking Home button.
4. Back up your current rom to your SD card if you haven't done it already.
5. Wipe data/factory reset
6. Wipe cache partition
7. Advanced -> Wipe Dalvik Cache
8. Mount and Storage -> format /Cache
9. Mount and Storate -> format /Data
10. Mount and Storage -> format /System
11. Install Zip from sdcard
12. Choose the .zip file you downloaded and placed on the SD card
13. Wait until installation finishes.
14. If you see any error during installation, DO NOT reboot.
Restore your phone with pre-made Nandroid backup.
15. If install was success Select 'Reboot System Now'
** See below
16. First reboot will take longer than usual.
17. Once it boots, set up your account & test all functions.
** Warning **
If ROM install finishes in 1 second, then there's something wrong with the install even though you see the success message.
There should be some delay when CWM installs this ROM especially when it says 'Installing System Apps and Files.'
Some people tend to skip formatting Cache/Data/System but I highly recommend to do these steps with this phone and this ROM.
UPDATE LOG
07/31/2014 - Version 1a, Google Playstore & TTS bug fixed. Apps updated
07/28/2014 - Version 1 initial upload
