Root [ROM]Liquid Gingerbread v1.52
At this point it seems to be all super fine tweaking. All of the most current GB roms run the same on my phone with what seems to be the same features.
Running fine for me so far.
Still recharging the battery after the whole backup, install, restore, setup tweak process so we'll see how the battery acts on a full charge. For me, I don't see much of a change from LGB 1.42 so far, both are very stable on on my phone.
This is the first GB rom that I have run that has correctly showed and labeled all of my music. Every other one has messed up the tags and can't read then correctly for some reason
I've never had any issues with music being tagged, but Bluetooth media audio has not worked properly in this ROM since v1.4. I wonder why he keeps switching kernels with each release?
YESSS!!!
I love Liquid hahaha, I was having an issue where auto brightness didn't function in 1.42 and 1.3, but this version fixed it and the phone is now working, and I even think it is running a bit smoother than it was before, less lag while swapping apps.
I am in love with this 1.52 hahaha.
I'm def experiencing less lag with this ROM than previous GB ROMs (though it's not entirely eliminated). However, the battery life isn't all that great. I wouldn't call it terrible, but not great.
Same here, battery life not so good. Might try Setcpu instead of pre configured settings for overclocking and see if that helps.
Flashed this ROM + 1.2ghz last Friday, over the weekend with near constant use I got fantastic battery life and the phone is extremely fast and responsive, way better than stock. I did get a random reboot when I dialed my dad, but other than that random reboot no issues. I did make several successful calls so I don't know what caused it.
Flashed two days ago with raidzero 1.2ghz kernel, and so far it's been good. I was running UD 3.2 and the battery life was terrible, had to recharge after 8-9 hours of little to no use. Now I'm still at 70% and been unplugged for over 14 hours.
I get excellent battery life with RaidZero on my BB GPA14 as well. I think his kernel is the way to go! :D
Homescreen redraw issues?
Anyone using Launcher Pro with this bad boy?
EDIT:
Just downloaded and installed and now realize that Launcher Pro is default with this ROM. I have never seen a ROM with anything other than ADW. So far this ROM is kicking ass. Way better than CM or SS.
I posted a new thread with a possible fix/explanation for this. http://androidforums.com/droid-roms/319948-gb-roms-not-reading-mp3-tags-properly.html Take a look and see if it applies to you.
