Root ROM: Liquid v1.3 Released
jackburnt
Liquid Gingerbread v1.3 Released!!! - Droid Forum - Verizon Droid & the Motorola Droid Forum
********************************** v1.3 Changelog (02/23/2011) *********************************
updated titanium backup v3.7.1 (credit joel bourquard)
updated the carhome app to v2.2.1.4 (credit peter alfonso)
advanced camera options now implemented in camera menu (credit cm)
show/hide clock or period, and battery sliver icon and percent options
primary launcher is stock launcherpro v0.8.3 (credit federico carnales)
new tweaked stock launcher available in switch menu (credit bd & dustinmmj)
under status bar tweaks in interface settings (credit sven dawitz & liquid)
readded new block and show ads script to system in settings (credit jrummy)
new options to split characters for text messages in mms options (credit cm)
removed all green from stock theme overlay in the source code (credit liquid)
new settings menu called profiles in settings and in power menu (credit martin long)
this option is a first in any rom and allows customization of different area profiles
sytem wide for complete control over notifications, ringtones, and many other options
fixed theming issues involving replacing statusbar pulldown background (credit liquid)
new options to wake the phone using volume up or down rocker button (credit sven dawitz)
based on android 2.3.3 built from source fresh and synced as of the today (credit liquid)
new gingerbread audio library updated and new dspmanager works (credit alankilla & cvpcs)
brand new tmobile theming engine is now built into the source (credit cm, tmobile & liquid)
update dark transparent contacts and miui music player on server (credit pistolpete & team miui)
new options to change actions when pressing or long pressing the search key (credit sven dawitz)
new raidzero kernel and recovery download options in goodies menu as well as options to switch between
launchers, music players, and contact apps under switch in the goodies menu in settings (credit liquid)
when selecting kernels or recovery from raidzero menu in goodies it will download file and reboot device
into recovery and you need to manually install the update.zip now placed on root of your sdcard for now!
newly redesigned behaviors, interface, lockscreen, and sound settings menu (credit liquid & sven dawitz)
default 1100mhz super lv kernel; compcache enabled with tweaks & improved battery life (credit raidzero)
fixed the landscape layout of lockscreen and background when using two sliders (credit liquid & nmiltner)
reverted to stock aosp keyboard to fix autocomplete and keep compatibility with theming engine (credit liquid)
Dammit. And I just flashed Project Elite! ROM FIGHT!
Been running this for a few hours and so far so good...Very snappy! Hard to tell battery life since I have been tweaking the phone...
Does anyone know what the "choose profile" option does?
Just installing now. I am having fun trying all these roms. Still havent found one I really liked yet.
choose profile is I think ring options. I clicked it and it had profiles for meeting, night , so on.
This ROM is quick! I've tried my hardest to bog this thing down, and there is no lag or screen redraws no matter what I do. Well done.
I've been using UD since the 2.0 release, but I might just jump to Liquid for good this time.
After a day or so, it's snappy as ever. Still can't comment about battery life.
I will say that this and Project Elite feel VERY similar. In fact, aside from setting titles, there isn't much difference except the profile thing (which I haven't used).
I've been running this for close to 24 hours, and I must say that it runs very well on my device. I haven't changed kernels or anything else yet from what was in the original rom, but I see no need to. I do miss the green keyboard, but that was just a personal preference. Also, the redraws on LP seem to be gone, and the 3G deal after calls seems to recover better on this one than the others. The only thing I have noticed is that it seems to zap my battery pretty quick, but that's probably because of my inability to set my device down :P
Ive been running this on the stock kernel for a while now. Im loving it so far, its very stable and quick. Only problem I had was I couldnt flash my go-to chevy kernel(boot loop). :(
Mine seems to work ok. at times it seems to hang.
Mine seems to hang more often than not.
I have updated to the 1.31 version, using the 1 GHz Kernel he recommends.
I did flash UD 3.0.1 and it seems to do the same thing so I am thinking its something bugging out in Gingerbread...
one thing known for sure these phones can act different on the same roms and kernels. hope it works out for you.
Hmm, I know that two different ROMs did the same thing, UD 3.0.1 and LG 1.3.1 both acted the same.
Its not too big a problem and I can always just set the brightness to manual, it is just a slight annoyance at this juncture.
1.1 and 1.2 versions of this rom ran great right away. However after a few days they slowed down so much I flashed back to froyo. Anyone had this experience with 1.3?
I'm on day 3... it's still running as fast as ever.
I did downgrade to the 1.0 GHz kernel. I experienced 1 or 2 random reboots while using Slacker and the Camcorder using the supplied 1.1 GHz kernel. Additionally, I was looking to improve battery life.
I did notice via the liquid website that v1.31 has been released, and 1.4 is in the works. Sounds like 1.3 is in great shape, but I think i'll wait until 1.4 to try out GB again.
Liquid Gingerbread v1.3 is simply fantastic! Been running it for days now and the battery life I'm getting is outstanding. 70% at the end of the day whereas it use to be 30% to 40%. And this is with the stock 1.1Ghz kernel. None of the other gingerbread roms I've flashed compare!!!! Butter smooth scrolling, no rom glitches, etc. A work of art if I do say so.
Agreed, I'm a huge UD fan, but I've been running LG 1.31 the last few days and it's been unreal. Battery life is somehow getting better, finished a full day yesterday at 70%. That's crazy, I used to be at 60% or lower just at the end of the work day. This is getting better battery life even after an extra 5 hours or so. I think this is due is large part to the new kernel, my phone has always been very picking about ulv and slv kernels, but it definitely loves this one.
This ROM might keep me from dropping $200 or more on a new phone in the near future...
After the latest round of GB Rom releases, I believe I have settled on this one. This rom is still silky smooth after five days straight of running just it (which has got to be the longest I have went without changing since initial root). Most of the glitches of GB seemed to have been solved on this one, and the easy theming helped me make my final decision.
