dannyinterwebz
I rooted with the 2.2 unrevoked forever method. I installed the fresh custom ROM and ROM manager, but when I try to use ROM manager, it tells me that I have to have Clockwork Recovery installed. What gives? I have it.
I have downloaded MYN warm two point two rom on ROM Manger premium. Could anyone walk me through how to get this rom up and running. When i go into recovery i cant find where the file is located... Any advice would be great thanks!
If you downloaded the ROM from your phone then look for .zip in the download folder of ur SD/card,move and paste where all ur folders are.Go into recovery and flash.
Yeah, I had the same problem. It seems that rom manager doesn't understand that you're running clockwork already unless it was flashed through it. So, just reflash it, like it asks you to. I did, and it worked fine.
True story. Just rooted my wife's evo tonight and when I installed rom manager it didn't show a recovery listed. I flashed clockwork to see what would happen and it showed up then. Made a nandroid, changed to amon ra as that's what I prefer for flashing kernels, put on Kings cfs 9, went back to rom manager and changed my recovery back to clockwork. I also took your advice from another thread and have a zip file for clockwork on the root of my sd card should I end up screwing something up and not have an amon ra nand I could temporarily flash clockwork. Best ofBack on topic: ^this.
both worlds!. I also took your advice from another thread and have a zip file for clockwork on the root of my sd card should I end up screwing something up and not have an amon ra nand I could temporarily flash clockwork. Best ofboth worlds!
I have mine set up like that now with the advice of Nov. also. Kinda the other way around with a zip of RA on my SD.
Do you have a link to the Clockwork zip?
Clockworkmod zips for all the supported platforms here:
Index of /recoveries
Do you have the link to RA .zip? I never found it. thanks.
Is there a zip file in there or just the img file? I just recently got an evo and more recently rooted so sorry for not completely understanding. I do get the difference between Clockwork and RA and I've switched between the two with RM and booted into both recoveries to try them out. I was going to try to flash between the two like novox recommended but I thought they needed to be zip files on the sd card. Sorry if I'm confusing zip vs. img. Thanks, all this information is fantastic!
