Root ROM Manger won't backup/restore
D
Deleted User
Guest
Trying to use ROM Manger to install or backup a ROM, it goes into recovery, and then says it has encountered an error. I've tried flashing all the ClockworkMod recoveries available (3.0.0.5-8) with the same error. Here is the recovery log:
Code:
Starting recovery on Sun May  8 13:41:58 2011
can't open /dev/tty0: No such file or directory
framebuffer: fd 3 (480 x 800)
ClockworkMod Recovery v2.5.0.1
I:Set boot command "boot-recovery"
Command: "/sbin/recovery"
ro.secure=0
ro.allow.mock.location=1
ro.debuggable=1
persist.service.adb.enable=1
ro.build.id=ERE27
ro.build.display.id=ERE27
ro.build.version.incremental=eng.koush.20100714.213609
ro.build.version.sdk=7
ro.build.version.codename=REL
ro.build.version.release=2.1-update1
ro.build.date=Wed Jul 14 21:36:48 PDT 2010
ro.build.date.utc=1279168608
ro.build.type=eng
ro.build.user=koush
ro.build.host=Koushik-OSx86.local
ro.build.tags=test-keys
ro.product.model=Incredible
ro.product.brand=verizon
ro.product.name=inc
ro.product.device=inc
ro.product.board=inc
ro.product.cpu.abi=armeabi
ro.product.cpu.abi2=armeabi
ro.product.manufacturer=HTC
ro.product.locale.language=en
ro.product.locale.region=US
ro.wifi.channels=
ro.board.platform=qsd8k
ro.build.product=inc
ro.build.description=1.22.605.2 CL161494 release-keys
ro.build.fingerprint=htc/cyanogen_inc/inc/inc:2.1-update1/ECLAIR/eng.koush.20100714.213609:eng/test-keys
rild.libpath=/system/lib/libhtc_ril.so
ro.ril.def.preferred.network=4
ro.telephony.default_network=4
wifi.interface=eth0
wifi.supplicant_scan_interval=45
ro.com.android.dataroaming=true
ro.com.google.locationfeatures=1
ro.sf.lcd_density=240
persist.service.mount.playsnd=0
ro.ril.def.agps.mode=2
settings.display.autobacklight=1
settings.display.brightness=143
ro.phone_storage=1
dalvik.vm.heapsize=24m
ro.cdma.data_retry_config=max_retries=infinite,0,0,60000,120000,480000,900000
ro.media.enc.file.format=3gp,mp4
ro.media.enc.vid.codec=m4v,h263
ro.media.enc.vid.h263.width=176,1280
ro.media.enc.vid.h263.height=144,720
ro.media.enc.vid.h263.bps=64000,2000000
ro.media.enc.vid.h263.fps=1,30
ro.media.enc.vid.m4v.width=176,1280
ro.media.enc.vid.m4v.height=144,720
ro.media.enc.vid.m4v.bps=64000,2000000
ro.media.enc.vid.m4v.fps=1,30
ro.media.dec.jpeg.memcap=20000000
ro.bt.chipset=Broadcom BCM4329-B1
ro.bt.version=Bluetooth 2.1 + EDR
ro.bt.stack=Broadcom BTL-A
ro.bt.stack.version=2.0.47.005
ro.bt.profiles=4270403
ro.cdma.home.operator.numeric=310012
ro.cdma.home.operator.alpha=Verizon
ro.config.htc.nocheckin=1
ro.HorizontalVVM=true
ro.HorizontalBUA=true
ro.ril.enable.prl.recognition=1
ro.rommanager.developerid=cyanogenmod
ro.modversion=CyanogenMod-5.0.8-test3-Inc
ro.kernel.android.checkjni=1
ro.setupwizard.mode=OPTIONAL
net.bt.name=Android
net.change=net.bt.name
ro.config.sync=yes
dalvik.vm.stack-trace-file=/data/anr/traces.txt
ro.factorytest=0
ro.serialno=HT04JHJ00173
ro.bootmode=recovery
ro.baseband=2.05.00.06.11
ro.carrier=COMMON
ro.bootloader=0.79.0000
ro.hardware=inc
ro.revision=0
init.svc.recovery=running
init.svc.adbd=running
I:Checking for extendedcommand...
I:Running extendedcommand...
Waiting for SD Card to mount (20s)
SD Card mounted...
I:Running script:
I:
ui_print("ROM Manager Version 4.2.0.2");
backup_rom("/sdcard/clockworkmod/backup/CyanogenMod_7.03_5-8-11");
line 1: unexpected character at 'u'
Syntax error in update script
You might check the file size of the backup. My last 2 backups of CM7 average about 428 MB. Other Roms may be more or less but if you have a real trunicated file size, you can rule it as the cause.
Ah, that must be it as my backups range from 500-600MB.
That sounds good for many Roms. I was thinking if you had a real small file size, it would be indicative of a problem. I've seen these partial backups before. If yours are 500+ I'd say the problem lies elsewhere. You haven't changed your bootloader lately by chance?
Yes, I am able to back up manually just fine, but it is a pain and would be much easier to do in ROMManger (as I used to be able to). The only thing that changed before I noticed the problem was updating the ClockworkMod Recovery. As I said though, I've tried flashing to all the old ones again, but it still doesn't work.
have you tried uninstalling/reinstalling rom manager?
you also might go into your clockwork mod folder(either with root explorer or on your pc) and delete everything but your "backups" folder. if you want to move the backups temporarily to your PC,delete the whole clockworkmod folder,re-install rom manager,then reflash clockwork and see it starts working then.
i know this does not pertain to you(obviously you are experineced in using recovery and working with your phone),but for the new rooters, this is post is exactly why *I* do not like to use (or recomend the use of) rom manager. it is,in my experience,not reliable.
Tried all that, still get the same error though :(
