Root [ROM] MegaTron 6.2.5
chevanlol360
Android Expert
MegaTron Features
⬛ JellyBean Statusbar Layout
⬛ Dcsms Toogles
⬛ Based of FF19
⬛ Init.d support
⬛ App2SD Support
⬛ Removed bloatware
⬛ Zipaligns at boot
⬛ Extended Power Menu
⬛ Optimized ROM
⬛ Online Nandroid Backup
⬛ OTA Support for the ROM
⬛ Rearranged Status bar Icons
⬛ ICS Settings app layout
⬛ New boot animation
⬛ Xperia Launcher
⬛ & Much more features to discover
Change log data
Code:
[B][SIZE="3"][U]8/11/13 Version 6.2.5[/U][/SIZE][/B]
⬛ Now able to change clock color/remove it
⬛ All Phones Now Run the Same Version of MegaTron
⬛ Bug fixes
_______________________________________________________
[SIZE="3"][U]8/05/13 Version 6.2.5[/U][/SIZE]
⬛ Removed Beta Status now GM AKA Final Build
⬛ Fix Notification ongoing text
⬛ Change a few system icons
⬛ Theme the system MIUI like
⬛ Speed up the entire system
⬛ Enabled CRT Effect
⬛ Changed Wallpaper
⬛ Bug fixes
⬛ Much More
Help Me Keep Megatron Going
If its Grayed out that means its fixed, if its bold thats what needs to be fixed/done
Known Bugs:
1. Quite a few things in Megatron app isnt working
2. Few toogles aren't working *Substitute them for your favorite apps Via the DCsms app.
To Do:
1. Add screenshot feature
2. Fix up Megatron app
3. Change a few system icons
4. Change Lockscreen Layout
5. Add sound Boosting tweaks
6. Speed up the entire system
7. Add init.d Scripts
8. Fix Notification ongoing text
9. Theme the system MIUI like
10. More
Disclaimer: YOUR WARRANTY IS NOW VOID Neither myself or my development partner are responsible for any damage you do to your phone. All of our files/development are always tested extensively by several testers. If you are not familiar with these methods, I'd suggest that you do some research elsewhere to better understand before you attempt anything on your device.
Downloads
MegaTron 6.2.5 GM
Add yet another device to list of supported devices for Megatron!!!!!!! Awesome Chev and CONGRATS! :D
Too freakin' cool man. :rock:
I have not seen anyone post any issues except for the missing keyboard. Is there any thing else that needs fixing? Im so ready to install this but the Prevail is my only phone and I gotta have it working for the telemarketers to bother me.
I'm waiting to hear feedback as well. I use this phone as my work phone so can't afford to have it going wonky on me! Still, I might try it this weekend. The keyboard thing isn't a big deal because I have TouchPal Wave on my SD card anyway.
ik its in beta but and i did wipe eveything, but here is what i found
-on boot it had stock boot music and it still had the logo from the previous rom i had on it then went to megatron logo
-when i go to about phone com.android.settings force closes
-power button menu missing the reboot option
-not rooted
if you need help idk if thy guy that did ctmod is still around but he might be able to help you that rom was satable
-not rooted
Im aware of most of the issues you mentioned, there in the to do list in the OP should be rooted so idk whats up with that.
tried out this rom when beta 2 came out. rom is working good for beta 3. some of my apps force close though like facebook maybe its just something with my phone but everthing is working fine:)
