mikekelso421
Welcome to Mikekelso421's AOSP Project.HOME of MetrogenMod 7.1
This is an AOSP rom i compiled myself and is my FIRST compiled from source rom.this is just cm7 with a couple things modified and it seems to run smoother with less FC's and my lockscreen is nice and smooth with no screen lag.try it out and let me know how it goes for ya.im running it on my evo now and its great! you will need Gapps as well,just like CM.
-MetrogenMod Rom- (Metropcs Flashed Evo's ONLY)
This is the same build as my other compiled cm7 rom but is configured to have MMS working RIGHT OUT OF THE BOX!! Simply "superwipe"+flash ROM+flash gapps+reboot!
These are my add-on zips,Flash awaY (these are not my work,just sharing for others to use)
Unvisible Tweaks (recommended)
GPS FIX (recommended if you want your GPS to work)
SUPERWIPE (wipes cache+system+boot+data x3 for clean wipe)
Gapps (google apps)
AmonRA Recovery (rename to PC36IMG.ZIP and flash through fastboot)
These are my ROM download Links,there are alot like it,but these are mine!
[I recommend a FULL WIPE before flashing this.If you choose not to wipe before flashing,please dont report any bugs or issues to me.i flashed and am running this now,everything is working.]
For Those of you on Sprint [Updated 2-21-12]
KelsogenMod 4.5 [Update-4] (sprint)
And for those of you with MetroPCS [updated 2-20-12]
MetrogenMod 4.5 [Update 4]
thanks everyone for checking out my thread! enjoy my rom and be sure to hit the thanks button if you like my work!
Special thanks to:
Ghost.Rider- for helping me thru the whole thing and assisting me with all my questions!
Bloodkillers-for the MMS script i used to make my MMS-READY MetroPCS ROM
CyanogenMod-for their AWESOME GB source
XDA-for one of the best forum sites on the net
AndroidForums-for yet another GREAT forum site! Best noob friendly environment ive been in!
Team KANG-For their AWESOME Contributions to the android world.
-MetrogenMod-
:12-14-11:
-added adjustments to the build.prop
-optimized every single png in all .apks in this rom (saved like 5mb or a lil more)
-light theming of framework-res.apk and systemUI.apk for a better stock look
-changed bootanimation because this is MY ROM NOW!! (POWNED)
-added ICS animations
-more coming soon!
:12-22-11:
-Completely reconstructed framework and systemUI
-Ported Official ICS framework and SystemUI pngs
-redid some icons to match the ICS framework
-made wifi scan interval 2min for better battery
-custom wallpapaers located in CM WALLPAPERS
-couple other things
:2-19-12:
-Started from scratch.resynced the GB repo source
-New features added by Team Kang (check out CM Settings)
-New Custom Wallpapers (Sense 3.0 + ICS)
-Removed Androidian (stock default is Cyanbread)
-added 2 sweet themes (not my work)
-included Unvisible Tweaks+GPS Fix
-2 min wifi scan interval
-others that i forgot.i def suggest flashing this new build.
-KelsogenMod-
: 12-17-11:
-more coming soon!
:12-22-11:
-custom wallpapers located in CM WALLAPAPERS
:Screenshots:
Gapps (google apps)
Special thanks to:
-MetrogenMod-
:12-14-11:
-more coming soon!
:12-22-11:
:2-19-12:
-KelsogenMod-
: 12-17-11:
-more coming soon!
:12-22-11:
:Screenshots:
