SantitasHeart
I see all my emoji
just an fyi theres a new version of xposed available
right here http://forum.xda-developers.com/showthread.php?t=3034811Where exactly? .-.
Doubt it he don't work like that he isn't gonna implement something with 0 benefitjust curious, so the kernel on this rom is not overclocked due to no perfirmance increase/ benchmark change but will possibly be implemented on the next release?
Flash the stock 10j firmware, the fact that you're having problems with both a stock rom and cm to me says that it's on your end. If you only flashed the bootstack go ahead and give flashing the whole firmware a try just to be sure, can't hurt anything.I'm having a weird problem with this rom.
Every now and again when I oom the kernel will panic and touches stop registering.
I have to pull battery. At first I thought it was just an xposed module until I disabled it on boot. Does it on both phones I own. One shipped with b and the other shipped with e.
I can't capture a log either because it seems to be random.
GT you know a way to increase touch screen sensitivity
It's not modded in any other way and it appears the black screen and touch screen becoming unresponsive follows an app not responding dialog. It happens with things like Facebook and browsers. I actually reflashed the rom and it seems to have fixed everything but it was definitely peculiar.If you're making oom changes causing the kernel to crash I don't see how that's a problem with the rom/kernel. The rom and kernel are provided in working order and any changes you make that break it are on you.
Post #35 will answer your question. The actual features of the kernel are listed in the first post.
I'm trying to slightly decrease sensitivity, any tips if you've had any luck increasing it?GT you know a way to increase touch screen sensitivity
I'll add links later.
