bustone747
kkHaha, sounds good man. Enjoy the rom GT put a lot of work in [emoji106]
can you post some screen shots of layers working on this rom pleaseMaybe this has been mentioned but we can use Layers https://play.google.com/store/apps/details?id=com.lovejoy777.rroandlayersmanager to theme this bad boy!why haven't I heard of this earlier it works like a charm
wow nice thanksView attachment 98345View attachment 98346View attachment 98347View attachment 98348View attachment 98349View attachment 98350View attachment 98351
You can't theme any stock LG apps but Google apps and third party apps work, as well as framework. Nav bar and status bar layers also don't work, but still better than nothing.
nav bar buttons?does it theme the stock settings app too?View attachment 98345View attachment 98346View attachment 98347View attachment 98348View attachment 98349View attachment 98350View attachment 98351
Double tap to wake is built into the kernel as far as I know so I'm pretty sure that the only way to disable it is to build a new kernel that doesn't have it.Anyone know a way to disable that double tap to unlock
Download and install https://play.google.com/store/apps/details?id=de.szalkowski.activitylauncherAnyone know a way to disable that double tap to unlock
Boost can use this ROMIf only Boost could use this...
I don't have this device I'm using a ROM that meant for T-Mobile I just flashed radio partition for boost bam works lolDo enlighten us, I'm sure many would appreciate that.
Wow I was thinking about getting this device too well therez root so u probably can manually insert the files in there designated areasBoost has a locked bootloader, and no twrp, I don't think that's much help.
Oh its possible to use something like adb to manually push the files into the system(after extraction of all the files from within the system.img) and get it to work, that's only if the system doesn't freak out and throw an error code your way.Wow I was thinking about getting this device too well therez root so u probably can manually insert the files in there designated areas
Open the app and change the top drop menu to all activitiesView attachment 98442After that scroll down and find settings tap it once and scroll down until you find knockon
For ease of use long click and select create shortcut
Now you can enable and disable at will! Please note this will disable double tap to sleep I suggest you use an xposed module to renable it, gravitybox is my pick.
This is way off topic but take this link http://bit.ly/1m6UtYi and head over to the cm thread and share it with them, maybe it'll help themIs there a way to pull this from the kernel and insert into CM?
Just install nova launcher n it will disable it. And if you need to enable it just install yhis and that's it https://play.google.com/store/apps/details?id=wq.lockscreenIs there a way to pull this from the kernel and insert into CM?
Say what!?Hello
I've been using this rom for a while and haven't had any problems except for one thing. The in call volume is extremely low, to the point where it's almost inaudible. I've tried resetting the phone, even re flashing, but still haven't found a fix. Any suggestions?
