G4 Tweaksbox barely works on Katana, smh . I hate when people reply in threads and don't know what they're talking aboutYes, and you didn't have to quote the op to ask that lol
Yeah it works ? The only wierd bug I found was when you change the quick settings toggle colors it shows an orange circle when its activated
I brought the key , I don't have a quick settings option in g4 tweaksbox anymoreReally? I've been on Katana since the first build and have always had G4 Tweaksbox installed and running 100%. You did buy the pro key right?
I got the same problem , the recent apps menu blur keeps going back to regular & I can no longer put the 7th soft key as g4 tweaksbox has an option to put back the menu softkey.Yeah it works ? The only wierd bug I found was when you change the quick settings toggle colors it shows an orange circle when its activated
No it's not needed but it certainly does add more to your battery. I set it up with PowerNap, Greenify, and Amplify. With this I get on a average day 5 hours SOC and if I'm lucky I'll get 6-7 SOC Props to GT and the whole Android community for these amazing tweaks and AppsBeen running Katana nearly 2 weeks. Battery life is ridiculously good. (Today)Nearly 3 hours since unplugging and the phone has not been used and battery is still 100%. Would Greenify or Amplify really be needed for this ROM?
Just gonna throw this out there but g4tweaksbox was built specifically for the g4, anything that isnt a g4 is gonna have some bugs since they use somewhat different code, framework, etc.I got the same problem , the recent apps menu blur keeps going back to regular & I can no longer put the 7th soft key as g4 tweaksbox has an option to put back the menu softkey.
Create as in make them from scratch? You'd have to download source from github and build it.. I THINK don't quote me on that. When I tried to flash gapps using opengapps aroma version it didn't work for some reason so I'm not sure it would work, and frankly I'm too lazy to backup and reflash atm
ok, thanks. so probably having them install from the play store would be better, I know we get a option to insall as new device or install previous apps via playstore so that's what I'll try.Ohh, not sure I would trust TiBu to make flashable zips, you can try though but definitely backup right after you flash just the ROM and partitions. Restoring apps may have been the problem, depends on the app though. Personally I had to reflash recently because my battery life was horrible for some reason, reflashed and watched what I installed and got 7 hours screen on time on the first charge, make of that what you will....
There is the UO CM12.1 rom.Is there any other roms that work on the G Stylo for merto pcs.
not true, G4 Tweaksbox worked fine on the Stock v10j Rom.Just gonna throw this out there but g4tweaksbox was built specifically for the g4, anything that isnt a g4 is gonna have some bugs since they use somewhat different code, framework, etc.
