JB in AZ
Android Expert
Mikfroyo 4.5
Mikfroyo discussions - ALL versions.
Use this thread to discuss all versions of the Mikfroyo ROM.
How do you use the sprint hot spot. Also do you have to do anything to rom or anythng else before flashing that kernel. ThanksI'm running this rom with the Netarchy 4.3 CFS more havs nonsbc kernel and getting AMAZING battery life, infact the best I have ever gotten since having the phone. It does come with the sprint hot spot hack, which in my experience works waaaay better than wireless tether, so to be honest I have not even re-downloaded wireless tether to try it. only thing with hot spot is that you can only do 3g, but I swear the hot spot with 3g is faster than wireless tether with 4g, plus 4g if your not plugged in sucks the life outta your battery like a suckubus
where can this kernel be foundI'm running this rom with the Netarchy 4.3 CFS more havs nonsbc kernel and getting AMAZING battery life, infact the best I have ever gotten since having the phone. It does come with the sprint hot spot hack, which in my experience works waaaay better than wireless tether, so to be honest I have not even re-downloaded wireless tether to try it. only thing with hot spot is that you can only do 3g, but I swear the hot spot with 3g is faster than wireless tether with 4g, plus 4g if your not plugged in sucks the life outta your battery like a suckubus
Thanks guys! A few more questions:
1) I assume I have to update the radio, pri and such in order to flash MikFroyo 4.3
2) Will I be able to use netartchy's 4.3 kernels with Mik' 4.3?
3) Is there a way to have a 5 icon launcher in Mik's (ie LauncherPro in Myns)?
1) Yes, it's based off 3.70 just like Myn's RLS5 is. If you haven't updated the radios yet (and you need to), then you need to if you're going to flash this (theories on whether or not you need to aside).
2) Indeed, you can. Not being able to use any sense based kernel in any sense based ROM is a rare occurrence. If such an incompatibility exists, the ROM developer generally clearly states it. In this case, you're free to use any sense based kernel that you want.
3) You're asking if you can use Launcherpro? If it's Android, Launcherpro will work. It doesn't matter which ROM you're using.
Thanks!! I've seen some posts where people were having issues flashing the radio combo pack using clockwork. I just updated to 2.6. Will I be able to flash the combo pack?
One other question, hows the battery life on Miks compared to Myns?
I used RA recovery to be safe. Both radio combo and Mik's flashed without issue. So far Mik's does seem faster than Myn's. Not totally crazy about the theme. Any others besides the stock and flat black?
. I'm not too sure about themes. The thing is, mikfroyo has a lot of optimizations that will get overwritten if just any old theme is flashed over it. He does have a link to this in his thread, though:i'm using 2.04 no probs
