Root [ROM] MiniCM-1.0.0-Beta2 (Wifi Problem)
Hi,
I recently using [ROM] MiniCM-1.0.0-Beta2 after i do full wipe and data format is still has the same problem occur.
Does anyone know any solution for that ?
thanks!!!
Have you read the instructions on the website?
QUOTE:
Instructions:
Download the latest ROM
Move update.zip to your sdcard
Boot to xrecovery
Make a backup in xrecovery if you want to restore later
Select "install update.zip from sdcard" in xrecovery
Select "Factory Reset" in xRecovery (no need to do this if you are already running MiniCM)
Reboot (first boot will take ~1-5 minutes, wait)
If you don't stick to the above instructions you might get various problems (WiFi, Data traffic, Bluetooth, App2SD etc).
In that case, and before reporting an issue, Make sure that your Baseband is ...015 (Settings -> About phone and baseband) and select "Factory Reset" form the top menu of xrecovery & Reboot
UNQUOTE:
You probably did a <factory reset> from the phone's <settings> after your phone rebooted :)
so like the instructions said - "WiFi, Data traffic, Bluetooth, App2SD etc" will not work.
cheers :)
I has done the following way which do factory reset in xrecovery and not in my phone.
For my stat is
Baseband .015
kernel 2.6.29
kindly advised T_T
