Root [ROM] Minimal Triumph v1.0.9 and v1.1 (Final Release)
Wow...really nice work with this ROM. Keep up the great work guys! Can we expect a themed CM7 TG-Reloaded ROM in the near future from you guys?
ziggy, can you please explain the difference between this and froyoscream, i keep hearing about bugs in fcs, they sounds the same to me.
ok sure.
they are both build off of the same base. the only things that are different are (obviously) the theme, and froyo cream has the notification power widgets.
the rest is the same pretty much tweak and speed wise. as for the bugs, when i run these roms i do not have any of the bugs
ok sure.
sounds good, also could i get the dock from minimal triumph in fcs? and how well do games run on here vs say cm7 or miui 2.3 variants? i know you have been working on the new gb rom, will updates still be implemented on these 2.2 roms?
yes the dock from minimal triumph can be used in froyocream. you just have to take the launcherpro_backup folder from minimal triumph and put it on your sdcard after installing froyocream. then restore the backup using launcher pro
where do i put it on the sd card i put in the actual sd card's home and it loaded the froyocreamsandwich dock
I know you can not activate motorola triumph when it has cyanogenmod 7 on it put can you activate the phone if Minimal Triumph rom is installed on it?
new update to v1.0.7 includes mantera's fock kernel and new egl drivers aswell as a new keyboard by b_randon14....... will be labeled experimental because when testing playing HD videos over a short period of time the phone starts to heat up aswell as front camera is upside down.....
heres new eye candy to accompany the update :D
Wallpaper for anyone that likes this :)
Nice.. hey I haven't flashed this over since I already am on the latest but FFC is acting weird .. everything is upside down not sure if the fock kernel changed anything. I don't use FFC that much but I wanted to video chat and like I said I was upside down lol. Is there a setting to fix this?
Yeah i just tested it is upside down my assumption is that the new kernel or egl drivers are the cause only solution i have is that after you take a photo rotate it until its right side up
i think we should put up 2 versions... one that has bkernel in it and the other has fock kernel. (both updated of course :p )
I tried flashing the new 1.0.7 over top of 1.0.5 and it booted to a black screen after the boot image (pirate android) so I tried flashing it after a system/cache/data wipe and the same thing happened. Maybe the new video drivers just don't like my phone?
Same thing happened to me.
