help please ! Went to download Mimi,al v1.0.5 on my new laptop HP Pavillion dv7 i7 processor with 16gb of ram and when i hit the download link on mediafire the download wouldn't start also noticed that when i hooked up my M/T to my laptop didn"t see it loadong the M/Tdriver allthough my M/T does show up on computer. yes usb was on. is it because i am on the cm7 tg reloaded that the driver didn"t install? Should I do a nandroid restore the plug in my phone or what.Somebody help me please! Gotta have this rom
Monsterz & Ziggy ,In settings > about phone >model, mine says ADR6400L. Whats going on there, on any other rom or foyro it says w435? Is this something yall put in or is it the refurbed phone that I have.
That would be the thunderbolt's model number. It's from the thunderprop build.prop mod. It gives more access to apps in the play store.
why and how more access to play store,
doesn't all androids have equall access
No not all androids have equal access because google lets devs have device restrictions. I think Gameloft is the worse at it. You can access hardly any games from gameloft on any android, but with the thunderprop mod you have more access since the thunderbolt has more access. Basically it thinks your phone is a thunderbolt and lets you download and use apps that would work on the thunderbolt, but not the MT.
ok,so i just bumped into this issue today,and it wasnt an issue before.i was on CM7,and i wanted to come back to minimal triumph.i had done a nandroid of it,so i booted into recovery,wiped data/factory reset,wiped dalvik,wiped battery stats.
now initially on this ROM i had to use GO SMS b/c the stock app had trouble downloading MMS pics.
now when i did the nandroid restore,everything works EXCEPT i can now no longer recieve pics.i must have done something wrong somewhere.
please advise?![]()
id exactly as you said,now everything works mint.I wanted to compare gaming performance between CM7 and MT. I used Heavy Gunner (it was an Amazon daily giveaway) as I think it is my most demanding game. It ran OK on CM7 (needs a little tweaking) but it kept crashing on MT 1.0.5.
Looking at the reviews, many people have problems running this game, making it either a good or a bad shakedown test.
Thoughts?
