Root [rom] miui4dx 1.8.19[updated 8/23/2011]
Raptor912
It's ready for download....
MIUI4DX 1.9.9
*NOTE*
the top link will take you to the latest version
-VoidedSaint
Many people have had issues with the later versions of MIUI. I and many others have stayed with the original version plus the patch which does NOT have the airplane bug nor the screen capture bug. I've been on this version since MIUI for the DX has come out and it's been nothing but smooth. No reboots good battery life. If you want to try out MIUI try this version out. Flash the large file first (1.7.22) then the patch (1.7.22.1). You can then flash the extended settings mod that I saved when this was the current version.
MIUI 1.7.22
MIUI 1.7.22.1
Status bar mods
-Aggie12
I checked out the site. On first glance it didn't say anything about the video working at 720p or not. Does anyone know?
^lol!
Voided Saint is trying it out now. He'll give me a straight answer. :p
So I can just flash this over cm7? If I want to go back can I just flash a backup?
Have nothing to do at work so might as well do something to pass the time.
VERY different, but very smooth. Lots to play with. How can i tell recording resolution on video?
its very iphoneish
and i do mean very, but it has alot of features that are pretty amazing, in all honesty i do not know how long i will keep it on my phone, its not bad at all, but kinda confusing getting started with it, if you have never done it before
its very iphoneish
video? 720p hdmi?
i dont have hdmi cables for my phone so thats a quick, IDK
video works, and so does video playback
full video?????????????????????????????????????????????????? really???????????????????????????????????????????????????
<-------flashing this tonight, tonight!
i just sbf'd
i cant take it
i bought an android phone, not an iphone, just not my style...
so im going to flash cm7 right now
i will take the battery life over an iphoneish droid x any day of the week
Just read about this on Droid Life. Looks interesting. I'm going to try it out tomorrow and report back on my thoughts on it.
i just sbf'd
i cant take it
the battery life is that awful on it?
one more question..i'm running the two-file, pre-rooted GB..therefore, i would need to SBF back to froyo and then root all over again and then go through the loading process for this rom?
TIA!
did you wipe data and cache before you installed?
Of course like a dumbass in my excitement to flash something new I did not. I was able to get into stock recovery though and wipe data, as soon as it finished it rebooted just fine into MIUI. Looks kinda cool, probably won't keep it though.
Now before I pull another blunder am I able to flash my CM7 backup or do I have to sbf and flash a nightly then restore?
Video is 480p only Steven. 720p video is going to take some time and effort IMO. I like MIUI so far; very fluid. Going to try out some themes to make it less iPhoney.
