I know 3G is a big deal but this ROM can be a real deal. Add HDMI on the top of that it will look like it came directly from Motorola itself as official update. Heck with Moto, with GPS fixes it can be better.
More like a fairydo you ever sleep or are you some sort of Vampire?
This ROM has really grown on me, it does have issues of course because of MMS, SMS, and 3G however after making some changes to some of the base apps it's working a lot better and the battery life is crazy nuts. If you opt to use this ROM I would highly recommend using Notification Toggle. It allows the ability to toggle Wifi, Bluetooth, GPS, Flashlight, and Power Menu so you can Reboot, Reboot into Recovery, Reboot into Bootloader, or Shutdown. All from the Notification window. I did try to add these features into hacking the frameworks.jar but have not had any luck yet as there is a lot of smali hacking that needs to line up perfect.
Just curious g60madman, do you ever sleep or are you some sort of Vampire?![]()
More like a fairy![]()
Now that I have a little more framework experience, I decided to take another crack at my GB build. I have everything "telephony" worked into the framework and got through all the phone force closes and boot loops, but now there is no service. Now it says no sim card instead of no ruim card. I think I may be getting close. I think I just need to revert a few things, and fix framework-res. Good luck on the kernel!Nice work I'll be looking forward to seeing it! Been focused on the kernel right now for cm9, however if you get that completed I'll spend some time on the data.
me tooI'm on the edge of my seat![]()
Thanks guys, it's still gonna take a while, don't want your legs falling asleep.me too
Don't count on ever getting FM on the Triumph. I am almost positive that we have a different bluetooth chipset than the other X6 variants, and the BT chip is where the FM is. We might and there may be a chance but basically everything except BT works on all of the other X6 variant ROMs, so like I said, don't count on it ever working.bsyds was u able to activate the fm radio in this i found a post that was explaining a way to change the band settings for moto triumph to activate radio
Forget FM, give us some 3G working and I say we have a fully working gingerbread rom.Don't count on ever getting FM on the Triumph.
