Aveamantium
If your S-OFF the installer will automatically install the kernel for you. If S-ON then you just need to select the S-ON kernel and it will boot to the bootloader to install it.
Thanks Nils! Ended up installing your Sense 3.6 version. Been using your Roms since the incredible. I need to try out your Sense 4 version!
