Root Rom noob, rom manager question
dgdave
I just got a droid and put froyo on it. I also put on a p3 kernel, the newest base band, and sp recovery. Love it. I just downloaded rom manager and the premium upgrade. I got the recovery on fine.now when I load a rom form the manager, it asks to reboot in recovery mode, but it doesn't. I also tried to boot up in recovery manually, but it won't go into recovery. Out just stays on the moto logo until I let go of the x and power then it just boots up like normal.
Thanks for any help
I am not positive but to boot in recovery mode using that rom manager i "think" you need to use clockwork recovery which it will flash for you in the program. No need to download anything. I did that and use the reboot and it worked fine.
go in rom manager and at the bottom is flash alternate recovery and all clockworkmod recoveries. Flash either SPR or an old clockwork then flash the current clockwork again. That should fix your issue
I tried both the alternate and an old and then redo the current clockwork again and it still will not boot into recovery. just get stuck at the motorola screen. I even tried buying the premium version and trying it that way and nothing. any help would be great. thanks
try flashing like 4 or 5 different recoveries then back to the current clockwork
