Acid burns
Member
Like its been stated when it cums to "mpcs"none of there phones are built tha same internally so I think that's why ppls results of this rom are hella different.
using the beats audio force closes any and almost all apps that uses an equalizer
Screenshot of this rom...the best rom for this phone IMO...79.00 phone for 50 bucks a month is the cheapest buy ever...thanks to everybody who is down with the android cliq
:car:
What icon pack r u using?
I just flashed the room and tried restoring the APn file but i still cant access the internet. help? I did flash the MMS Fix also after I flashed the OS. Does it take awhile for my browser to work after a fresh flash? I didnt get any 492 errors, I see a 3g icon and bars, just cant connect on my browsers. My google play store works and everything.
Good Luck. Hopefully someone is still awake that knows something we don't. I just tested, my MMS works. So RECAP: MMS works, Google Play works, email works, browser does NOT work(tried stock and dolphin browser).Same problem im still tryin to figure it out
I tried Opera Next and for some reason that one does work. Do you have any idea why? Default browser and dolphin HD dont work.Try Opera. I had a similar issue not too long ago, I guess certain browsers access the internet differently.
Sent from my Admire running OA2.3 by Spz0
My support is limited for MetroPCS, since I am on Cricket Network. I have a donor mpcs phone, but obv. no service, so there are a lot of issues I cannot address. I'll help where/when I can, but ftmp you Mpcs cats will have to rely on eachother to help get issues solved.
~Cheers
So how can we fix the connection for the browsers
I did a wipe data/factory reset, wipe cache partition, wipe dalvik cache, and then I flashed the rom. After the rom finished flashing, I flashed the MMS Fix, and when the rom first booted up, I waited like 30 minutes before I tried to open the stock browser. After I noticed my stock browser was working, that's when I connected my googleplay/email account.So how can we fix the connection for the browsers
