missladyt2010
I have a ROM already flashed on my EVO and I wanted to know how do you flash another ROM. Do you flash over it or..
Yes, just flash another ROM the same way you flashed the first one, it will over-write the previous ROM. Be sure to make a nandroid backup before flashing anything, it may come in handy at some time. Then clear data and cache before flashing a full ROM - ROMs work best on a clean slate.I have a ROM already flashed on my EVO and I wanted to know how do you flash another ROM. Do you flash over it or..
+1, great tutorial!ok so here are the steps to flash a rom:
1.download and transfer rom of your choice to your sd card
2.go to recovery. power off then press and hold power+vol down. this will get you to hboot. select recovery
3.from there before you do anything, make a nandroid backup. anytime you make changes to your phone always make a nandroid backup.
4.wipe system, dalvik cache, and cache
5.select "install .zip from sdcard" and find your rom file and select it.
6.select reboot
now it may take a bit for it to boot up because it has to build up dalvik cache. so dont worry too much if is taking awhile.
another thing i would like to say is that do not use rom manager. it tends to be buggy and i think it is much easier to do everything manually.
hope this helps. any questions feel free to ask.
If you're using ClockworkMod recovery, boot into recovery. Use the volume buttons to move and the power button to select.How do you make a nandroid backup?
