Root [ROM][RC][5.1.1][O3] Liquid Smooth 8/28/2015
phenomx4
Android Expert
Recognized Developer
This is a beta release of Liquid Smooth for the Zte Warp 4G so please don't expect this to be 100% stable. Before flashing this rom I recommend you make a backup just in case. Please report and bugs you encounter, preferably with a logcat.
About (Taken from liquid smooth website)
LiquidSmooth is an aftermarket firmware based on the Android Open Source Project.
Dedicated to providing users with smooth, stable and fast ROMs. A Lightweight modified AOSP base, and then add the features you crave!
What works:
    • Audio/speaker phone
    • Camera
    • Headset/headphones
    • Calls
    • Text/MMS
    • Touchscreen
    • Lights/brightness
    • External SD
    • Bluetooth
    • Wifi
    • Proximity sensor
    • MTP
    • GPS
    • Tethering
    • NFC
What's partially working:
    • Nothing
What's not working:
    • Nothing
Issues:
Change Log (source)
Click
Change Log (device)
HTML:
8/28/2015
Fix gps
replace audio fx with Viper
sync up with latest source
I think that's it?
8/11/2015
Initial release
Credits and thanks:
LiquidSmooth
SuperR
ZTE
Patches:
HTML:
None
Gapps:
https://github.com/cgapps/vendor_google/blob/builds/arm/gapps-5.1-arm-2015-07-17-13-29.zip?raw=true
or
Minimal from this thread:
http://forum.xda-developers.com/android/software/gapps-google-apps-minimal-edition-t2943330
Download:
https://s.basketbuild.com/filedl/de...9510/LS-LP-v4.1-2015-08-28-liquid_warplte.zip
Screenshots:
Comming Soon
While donating is not required to use this rom it's always appreciated
Donations:
Been on LS for a day or so now and must say that the battery consumption isn't too bad!
Lets hope my device gets activated today, ive been trying alot of rom's and i just restored stock to get it activated, idk if they care if its rooted/custom rom and recovery though
Stock & JollyRoger4G will allow activation but unsure of the others (cuz I just don't know)
Don't mention Root or recovery. They have you use the dialer for a reset code. No problems
Ive been having an issue with the google play store, i havnt modifyed it in any way, but after installing Gmail on 2 diffrent install's then it, not working and uninstalling it, it crashes com.android.google.gsm over and over. i dont know if this is only this rom, but incase anyone else is having the same issue, i wanted to let you know.
No. Issues runs great been running 7 days
Try reflashing ur op again and make sure u go Into recovery in advance and clear ur devalk cache
