Can someone give me pointers on how to change the default application in the launcher on BB 6.2.1? It's something simple I know, just overlooking it.
Thanks.
Just press Home and itll give you an option of which launcher you want to use
Make sure you check the box that says use this launcher by default
That doesn't address my question. Those applications in the launcher...I want those changed.
As far as what you said: It doesn't do what you think it does.
Um, just press and hold the application then it gives you an option to change them...
No, it doesn't. I have dialer, talk, browser and email in my launcher. If I press and hold, no matter how long, it only opens that application.
The default launcher is the way Pete set it.
So much for customization. Poor move. How would I change back to stock launcher?
Press home. Round and round in circles we go
Pressing home does nothing mre than take me to my home screen.
Leave aside the smart comments.
Please read my original post if you have not already done so. You might find that it would be helpful in determining what we're discussing and your ability to lend pertinent information to the discussion.what exactly is your question lol
You're not getting it - that *IS* the stock launcher.
Not in the stock launcher by the user in the OS. Alternate launchers have docks that can be changed.
That is why someone above told you to press home - you have the stock launcher.
But as I said, pressing home does nothing to let me change to another launcher as default.
It really doesn't matter and is no longer worth it.
I've noticed that I have not been getting notifications for a few apps lately. If it were only one app I'd think it was that specific app, but at least two have been missing from my notifications bar since I moved to BB 0.6.2.1
Twidroyd
Words with Friends
WeatherBug Elite notifications (ongoing) does not update
Has anyone else encountered? Is it possible the ROM isn't playing nice with my phone? I came from UD which seemed to work fine, I Just didn't like it.
Twidroyd
Words with Friends
