Root [ROM] [THEME] Sense Rom Optimus M
Is the latest update working for you?
  • Total voters
    74
joneidy
Ladies and Gentleman proudly presenting a themed 2.2.1 Rom that looks like Sense UI.
And other addons and modifications that I hope you people like.
To flash go to recovery, then select wipe and select Wipe All User Data. Go back and now select flash from zip menu then disable signature verify. Then select Flash from zip and look for the downloaded .zip file and select it.
Hope that those quick instructions help you guys :)
A2sd support: Create a partition using custom recovery to enable a2sd. Make sure that partition is on ext3 format. Make partition before flashing rom. **Backup your sdcard because during partition it gets formatted.**
DOWNLOAD
MD5 Sum: 970C972F9777FF6C528814A2C814B47D
Tested before uploading. Everything works
Thanks to the guys over at XDA Forums
And also thanks to asadullah for guiding me through modifying things.
Changelog 5/5/2011
New Shared uid
New launcher
New status bar
Modded some apks
Blue volume bar
Added battery percentage
Blue scroll bars
Changelog 5/15/2011
Fixed Video Playing issue
Fixed Wifi Location
Updated to last Root Explorer
Changelog 5/30/2011
A2sd support added
Changelog 7/18/2011
Redid Status Bar
Added Reboot and Reboot Recovery to Power Menu
Bluetooth now WORKS (Tested by teh_dude)
Updated Superuser
All Gapps Updated
New Music Player
Overclocking capable using r.O.C.K-v0.3 (Thanks to reppard for this AWESOME kernel)
New boot animation
New boot sound
Updated Launcher
Added Phandoid App
And some other minors mods
wow. and here i've been messing around in windows and ubuntu like a chicken with my head cut off, trying to learn how to make my own themed-out roms (mostly wanting a black/transparent kind of a look), and then i see this, which is pretty darn close to what i wanted. i'm not giving up my little project (got a waaaaays to go), but I'll definitely be sporting this ROM in the meantime. Thanks abunch joneidy!
Your Welcome just hit the thanks button. LOL
noob question: what is the paintbrush-looking button on the right of the dockbar supposed to do? I see the settings say you can customize the LAB and RAB, but haven't found how.
You can just drag any app to that icon and it will open that app. I personally have browser under that icon. But you can use whatever app you want there.
Hope it helps
I wanna thank both you and asadullah for all you hard work. please continue to your magic. Now only if they gave us that dam source code so we could overclock.
ps i didnt see a donate link to you so i have not been able to.
i have donated a little to asadullah for his hard work.
leave me a link or a paypal address and i'll be happy to give you some support.
thanks again and have a happy easter
Do you plan on making any tutorials?
Im having trouble changing the default skin of the clock to the one that is in the picture. Can someone help me with that? I have went to download from server, clicked the first mirror link, but after it downloads nothing happens.
Also, I was wondering if it were possible to somehow get the widgets that LauncherPro Plus had (calendar, people, and what not)?
EDIT: Nevermind I got it fixed, and I just reverted the dock to launcher pro. Thanks for the clean ROM!
Hope it helps
Can the icon itself be changed?
I dragged the browser into there, and it launches it fine, but I was hoping the icon would change. Seems odd to have a art icon for browser.
I use ADW Launcher EX and Launcher Icons Pro. You can change the dock, and customize all the icons. But you need Applanet. :p
this is,by far,the cleanest looking rom for the optimus yet.in my opinion anyways!we need more roms with color in the status bar.and this one is SWEET! reminds me of this CM7 theme called ROVER.i love this ROM!! thanks Joneidy! BTW if you get adw launcher and theme it with the DROIDBERRY theme,it looks GREAT on this rom!
