KenjiMishima
I plan to use this rom later, but first Id like to know does it change the network your under, Ex: CM7 changed network and now certain things metro related do not work. Witch is a bit of a bother.
CM7 doesn't change network. It removes hidden menus and Metro Bloatware.I plan to use this rom later, but first Id like to know does it change the network your under, Ex: CM7 changed network and now certain things metro related do not work. Witch is a bit of a bother.
So...there is a an app that will locate my phone if stolen, and make me able to file a claim and get my phone replaced?CM7 doesn't change network. It removes hidden menus and Metro Bloatware.
Whatever metro software you miss there are better alternatives on the market.
i wiped and flashed this rom, with darktremor's a2sd 2.7.5.3 beta 4, and stagefright in that order and when i go use titanium backup to restore my apps it reboots and thats everytime any assistance/advice?
Lukaslukasm - Not sure if you've already resolved this, but Im almost definitely sure Sense ROM has DarkTremor scripts already written in it, so no need to flash dtapps/DTremor after flashing SenseROM - not sure what version it is tho. Now with CM7(Reppards) it does not have DarkTremor scripts in it, so you'd have to flash dtapps... HTH. Yesterday I had problems with Titanium also, maybe uninstalling TiBu then reinstalling again may help cus it did for me. HTH
i know sense rom comes with the scripts but the reason why i left this rom for reppards cm7 before was cause of a2sd messing up on me so i want to flash atapps but i guess ill see how it goes w/o flashing the scripts
How?? Please do tell
Let me know how it goes. I flashed Sense last night and once again, for me constant reboots. So now I'm back with CM7Reppards, but still having reboot issues. I'm now going to follow TripDoc(?) thread and backup/repartition sd-card and reflash CM7 plus dtapps and see how that goes. Also I see you are OC @ 806??How?? Please do tell
Try Playfulgod's or Bobz's CM7 ROM, no reboot issues, but the camera is inverted, so if you can tolerate that until they fix it, their ROMs are awesome
Danielle, tbh, asking someone how they overclocked their phone to X when you can only overclock the same phone to Y under the same circumstances is kinda like asking someone how they got their skin color. They didn't really play a role in it heh. Say a batch of 100 processors is made, all for the Optimus M. 10 of 'em can hit 825 mhz or so, 1 can hit 864, 19 can hit 806, and the rest vary between 729 and 748 or so. Whether it's a cell phone microprocessor, or an intel or amd chip for your laptop or PC, the same principle applies from what I understand--they're always going to set the stock speed at something below what all of them can actually do, because none of them are consistent in what they can actually do. it is an imperfect process on the nano-sized level of things that cannot be perfected.
- actually just trying to make sure nothing else I can do - I can't go past 600-729 w out rebooting - seems little unusual.
I know, I know - you definitely have a point, but I can try- actually just trying to make sure nothing else I can do - I can't go past 600-729 w out rebooting - seems little unusual.
for your question above DaniellieeE, before i was 787 with performance govenor but when i used smartass v2 i went up to 806 and nothing went wrong... even though i dont like that govenor now :/ and im now restoring a nand backup i had of reppard cm7 sense still messes up on TiBu :[
Previously my phone was on android 2.2 with rom zero installed. OC i couldnt pass stress test for more than 30 mins without rebooting at 748 so i kept it at 726(i think is correct). Now after flashing with this rom on 2.2.1 I tried 748 and stress tested all night. Will be trying even higher tonight!
Thanks much for response. Are you still having problems with a2sd? I was still having reboots so last nite flashed BobZCM7 Rom and I'm liking it so far - a2sd worked perfect, and files were all there (BobZ has a2sd scripts). I think I kept having problems because I still had old Recovery (Joneidy's) image still on my phone. Last nite was able to replace it w GetItNowMarketing's Image and was finally able to do nand backup of my sd-ext w out getting an error - thanks again![]()
I had a2sd problems on sense ROM not cm7... With reppards cm7 I can't receive or send SMS a lot of times mostly receive and also phone calls and the only problem I have with sense is TiBu reporting my apps causing a reboot
