Root [ROM]~* UB-A75-1 For A75 ! *~
+ hay wait !
hope u used the build.prop in the ROM !
MpOBJeQY
are this rom could recognized ext4 sdcard filesystem and flashplayer armv6 built in. cos i have desperated couldn't use link2sd to use ext4 filesystem, and for the flashplayer armv6 even i can installed it and have been put the flashplayer lib file in /data/data/com.......flashplayer my stok browser still couldn't playing flash file on the sites. try opera mobile and dolphin hd browser got same no luck :(
For Link2sd ext4 u need kernel support !
any ROM cannot do it ...
u need k.source code if u want it :D
use FAT32 partition it will work :) and further discussions on Link2sd on this thread --> http://androidforums.com/a70-all-th...l-install-thousands-many-more-apps-phone.html
for flash player refer this : http://androidforums.com/a70-all-th...-flash-player-10-3-work-your-finger-tips.html
I am never add flashplayer in my ROMS as I think having flashplayer in mobiles is like
:D
document viewer & editor is not there in this rom....
when did i say that it was there :D
u can always one from the Android Market !!
I have added nano text editor which is a command line, open source editor and viewer ! It is amazingly powerful if u gonna operate something from Command lines :)
ok can u tell me one more thing...................... what can i do for change the songs from my headset (headphone) button in micromax i am unable to do it
or
can i play songs via bluetooth ear piece
suggest me..
or
suggest me..
Well , I will have to go deeper :D
Plz tell me 2 things :
1.) ur headset from which u change songs !! not the mmx one !
2.) was it ok b4 the ROM on the mmx updated zip ?
great, thanks ninad ninadchaudhari based on your link for flashplayer, now "whatismyflash" website can detect flashpayer :eek: installed on my device but only with uc web browser it get work, that's nevermind and once again very big thanks :D
no they were not changing before also i just want to do that by any thing i had tried many headset and bluetooth devices but it cant so plz suggest me by any thing if that happens....
New ROM installed today morning...... realy awesome. Thanks a lot, ninadchoudhari...... you rock!!! And the fact that you do not own a MMX A75 and still manage to do such wonders...!!! Really marvelous effort. (I pressed the button yesterday itself.. :) )
One thing I would like to point out here, for the information of all. Before you start flashing, before switching off the mobile, please remove all alarms set earlier. Today, while I was about to do the flashing with phone kept off, it switched on by itself, so as to play an alarm which I had set earlier. I doubt, if this happens during an upgrade, there are chances for bricking.
How do I change the default launcher settings? I want to increase the launcher buttons from 3 to 5, and change the app drawer scrolling from verical to horizontal. How do I do that? Please tell me.....
Glad :)
For the launcher stuff, I have replaced the mmx to the Original Gingerbread launcher !
You can download many launchers !
Just simply go to Android Market !
Go-launcher is gr8 but if u love speed greater than customization , I will recommend Zeam Launcher ! its the fastest out there ...
Both mentioned have 5 buttons than 3 !! more over u can simply slide between buttons screen ( i.e the total buttons become 15 ( 3 button holders, each holder with 5 Buttons in ) in Go-Launcher . Go-launcher is really amazing but may cause a bit of lag if u do a lot of customization !
Glad :)
I was using Zeam Launcher prior to updating. I will install the same anyway. But the Launcher provided in the ROM is really good. Can the same be modded to add more buttons?
Lol.....ninad we got it
Gta what u want in the ROM?
Sorry for being off topic.
Gta pm me and ninad about requirements and suggest something
