[Legionnaire]
Good day to everyone!
This is the most stable ROM that exists for ViewPad 10s. ViewCOMB 3.2 is based on VegaComb 3.2, including all updates. My idea was to adapt VegaComb for ViewPad 10S. I made few cosmetics changes on VegaComb, added some applications, and made some tweaks in kernel. All credits goes to the VegaComb developers. Thanks to Newbe5, Rebel1, Ejtagle, Corvus, Cass67 and all VegaComb developers.
Changelog:
Build 7.2
- 160 MB GPU (This should stop browser fc's)
- New kernel (Ideally should be used with a 352 MB swap partition)
- New WiFi drivers
- Increase framebuffers to 8 MB each 720P HDMI output
- Video playback grainy set to 32bit depth
- Disabled allow nvmap to use system memory and reclaim iovmm which gives a slight performance boost
- Keyboard power button debounce interval set to 50
- Boot issue fixed
- Some apps have been removed (OS Monitor, Terminal, ViewCOMB Screen)
- System partition size: 160 MB
Build 7.1
- Boot issue fixed
- Added new Android Market v.3.4.4
Build 7
- Rotation lock switch has been enabled
- 80 MB GPU
- New WiFi drivers
- Added Hide TaskBar app
- Added OS Monitor app
- Added Terminal Emulator app
- Added ViewCOMB Screen calibration app
- Added Music v4.1.511 app
- The most apps from system partition were transferred to a data partition
- Managing memory space is improved
- New kernel has been compiled
- Minor kernel fixes
- System partition size: 130 MB
Build 6.3
- Full Screen HDMI
Build 6.2
- Stable 1.2GHz CPU mv
- Support hidden networks (SSID)
Build 6.1
- New WiFi drivers (Proven WiFi & Bluetooth can operate at the same time)
- Working EAP MSCHAPv2 WPA-Enterprise
- New Android Market v3.3.12
- Minor ramdisk fixes
Build 6
- RAM memory lack fixed
- New wifi drivers
- Bluetooth improved
- Color deep fixed
- Possibility of increasing CPU frequency to 1.2GHz
- Power management fixed
- Added new Movie Studio v1.1
- Added new Google Maps v5.12.0
- Added new Android Market v3.3.11
- More stable
Build 5.1
- Added Ice Cream Sandwich Clock
- Added Animated Clock widget
- Added Digital Clock widget
- Added Email widget
- Added Lock Screen widget
- Added Weather widget
- Status bar has beeen changed
- New wallpapers
- App Launcher with 5 rows
- Added new Honeycomb Market
- Added Music3 app instead Music2
- Added Shuttle Tools app
- Added Drive Mount app
- Added Draw app
- Added Movie Studio app
- Added eFile app (better file manager)
- File Manager has been removed
- Google Books has been removed
- Updated camera libraries
- Working USB Host
- Splash screen has been changed
- Boot animation has been changed
- Default wallpaper has been changed
- System partition size: 155 MB
Download:
ViewCOMB 3.2 Build 7.2
Installation
First install USB driver for ViewPad 10s. Download driver: ViewPad 10s USB driver
Step-by-step instructions for driver installation: PDF
Open PDF file, go to the page 4, follow instructions from step 1. to step 8. Close PDF when you done step 8.
If you are sure you installed driver correctly, download file ViewCOMB 3.2 and double click on it. Wait few minutes to finish installation process, then turn on your tablet.
That's it! Very simple and easy.
Enjoy!
More screenshots here.
(for 40mins with display turned off, something might be wrong on the power management anyway)
