[Legionnaire];3778245 said:Build 7.2 is online
- 160 MB GPU (This should stop browser fc's)
- New kernel (Ideally should be used with a 352 MB swap partition)
- New WiFi drivers
- Increase framebuffers to 8 MB each 720P HDMI output
- Video playback grainy set to 32bit depth
- Disabled allow nvmap to use system memory and reclaim iovmm which gives a slight performance boost
- Keyboard power button debounce interval set to 50
- Boot issue fixed
- Some apps have been removed (OS Monitor, Terminal, ViewCOMB Screen)
- System partition size: 160 MB
hi..thank for the 7.2 rom..but for 10s 3g, 3g function still cannot use..at starting when put simcard..its detected 3g/Highspeed..but after 1min...it dissapear..and it said no internet connextion at the bar...is there any update/software to make 3g function?
Anyone know of a workaround for this? Also i would like to make a nandroid backup so if i do have to reflash the ROM i dont have to start ALLL over with installing apps and getting everything set up how i want. Any help on using clockwork mod with the ROM to do this, and then how to install the backup. I have an SD card so im good there. Im currently doing some research on how to do this but not having much luck. Sorry i have been such a pain the last couple days just trying to get this bad boy all set up to i dont have to do any more tinkering. Until the next ROM comes out lol. Thanks in advance to anyone that can point me in the right direction here.
) and i wouldnt know where to place the file if i did have it) and doing a backup through CWM? Sorry again ladies and gentlemen for being such a pain in the A$$ here and appreciate any time and knowledge you can lend a Noob with a capital N like myself.
