d4rk13l4de
i just rewiped and reinstalled the rom so far so good
ok, here is one last little problem, im not getting any notifications from facebook any ideas?
It works fine now, just need to make the fonts change.
i did that and selected the font i wanted and it didnt apply it to the phoneIf you open the Viper Hub app, there are a bunch of different fonts you can load up.![]()
these are the settings that I had already implemented.WiFi tether -
generic ICS/JB wlan0 profile
mss clamping
routing fix
I don't use it, but those are the preferred settings.
Can Viper 3.1.4 be flashed over 3.0.1, or do you need to do a clean install? I am still S-ON if that matters.
One of the earlier revs won't OTA, it's probably that.
Gotcha! So in your opinion would you flash over or do a clean install?
I'd nandroid first, then flash over. If that's buggy, do a clean install
That's weird, its never done this to me.
What version are you running?
do they still update this? i haven't received one update yet. also is there a way to update the google wallet app to not say unsupported device. also does anyone else have paypal here on the 4g lte?
