Root [ROM][WIP] Atrium JB
zjones
Member
Update 2: I'm now working on a new JB Rom, if you want to check it out, here is the link: http://androidforums.com/reverb-all...fusion-jb-new-version-atrium.html#post5947603
Update: Unfortunately, I am no longer supporting Atrium JB. I can't keep up will all of this stuff and don't have a good place to upload to. I will still continue to post customized ROMs, but don't count on consistent releases.
Archived:
Atrium JB
I am not responsible for anything that happens to your device, computer, sd card, etc.
Version 1.1
Release Date: 5/26/2013
Android Version: 4.1.2
Features Added:
-Added Apex Launcher
-Removed Touchwiz Launcher
-Removed Samsung Account Services
-Removed VM Bloatware
Bugs: Please Report!
-Minor freezing issues (Fixed it somewhat, still working on it, a hard reset will usually fix)
Download Link: Here
Mirror: (Thanks to siyangqiu) Here
Instructions:
1. Download File
2. Flash in CWM
3. Factory Data Reset (Optional)​
Version 1.0
Release Date: 5/24/2013
Features Added:
-Removed Most Samsung bloatware
-Added Stock 4.2 Gallery and Camera apps
-Added Clock app from CM10.1
-Added Stock Messaging App from CM10.1
-Rooted (w/ ChainsDD's Superuser)
-Added CM10.1 Launcher
-You Switch Between CM10.1 Launcher and TouchWiz!
-Samsung Account Services still needs to be removed.
-Freezing issues.
Credits:
Dsixda - for Android Kitchen
Download Link: Here
Instructions:
1. Download File
2. Flash in CWM
Click to View Screenshots​
Check out the original post now. Screenshots are uploaded. btw, ROM is still a WIP, so it's not completely done yet.
so you removed some apps... added a few... rooted... and called it a rom????
hate to break your flow here... but unless you create a device tree and build from source... its not a rom... just moving around some apps...
OK, I downloaded this morning, and got nothing but a bootloop with a backlit screen. I tried per instructions on the OP...with and without wiping data; then reverted to the zjones JB zip and tried both ways from there, finally back to tylers ICS rec. file and tried both ways from there; same result. Not sure just exactly WHAT'S going on with it, but that's what I got to report at the moment...will stay watching the thread for other posts & reports...
Peace,
Sox
Peace,
Sox
Hmm...I just tried it and it worked fine. After you wipe data it will take a while to boot (up to 20min)...
When I flashed, I went from stock JB. I will make you a backup of Atrium in just a second.
It freezes a lot and by freeze, I don't mean just a slow down. It actually will black screen and I will have to hard reset it every time. So far, it hasn't mattered which app I have used.
On my device, I have seen a little bit of freezing, but I am working on it now and it will be fixed in version 1.1.
