I'm running [ROM][4.0.4][WIP] Super Helado right now. Can I flash this rom even though I'm currently running an ICS ROM? I want to give JB a try. And if for some reason I run into a problem or miss Helado, can I return (flash) back to 4.0.4 Helado?
yes flash away... but make sure to wipe both system and data before flashing...
to backup... you can use the backup feature in cwm... or use titanium backup...
May I make a request or maybe you can direct me to where I can find it. When I used Super Helado rom, it had built in "Apollo Music Player." This has been my favorite music player I have found. I have searched however and cannot find it anywhere as an apk. Could you add it to your rom or direct me to an apk?
r u wiping data and system between flashes?It seems that most everyone else here can flash these roms but me. I've tried 1.0 (both versions)and 1.1.....the only ones I can get to boot are the stock 4.0.4 from tyler1998, and the original 4.1.2 JB you put out, z. PartTime JB from SuperBoy4444 gave me some problems at first, as well as Super Helado and all the previous others; but they eventually started working.
1 common denominator with ALL of them, though; they ALL flashed from the card, but threw a bootloop at reboot...ALL went to a blank, backlit screen after the Samsung logo and yellow triangle.
I'm gonna look back at my posts in the other threads around the time P.T. JB 2.4 finally pulled up in my phone, and see if there's a common link somewhere.
Peace,
Sox
Peace,
Sox
I still have no luck on getting any wifitheter workin w jellybean even I have root access,I might be downgrade cause its workin w no issue on root ics
I might hold out on this one until at least the rest of the Samsung bloatware is gone. This is very exciting because there has really been little development for this device since it's release. Honestly I'd love to see a rom for the Reverb that has Beats and Apollo and a theme changer for the status bar. The T-Mobile one that CM uses would be a good one. I can't seem to find any real theming options in the stock JB.
