Omg!!! Thanks a ton Bobz!! But do i still need to flash backup modem zip??
if you are going to install CM10 and monkey with it to try to get 4G working
you should backup your modemst partitions
If you are going to just use CM10 and not mess with the setting, RIL setting and stuff, you probably do not need to do it.
However it is always a wise thing to have a backup
