BobZhome
Developer: Blarf
Builder: BobZhome
Current Version: CM7.2.0 RC0-LW690-BobZhome (1-17-2011)
Description: Well, let's be honest. Unless you're living under a rock, you probably know what Android 2.3.7 (Gingerbread) is. Furthermore, you should know what the CyanogenMod project is. However, if a rock is really your home and you'd like to learn more, please visit their site: http://www.cyanogenmod.com
People worked with/owe thanks to:
What Does Not work?
1-17-12:
12-2-11:
10-17-11:
09-30-11:
09-16-2011:
09-08-2011:
09-05-2011:
09-04-2011:
08-22-2011:
08-17-2011:
Download Links
NOTE: If you end up having issues, always go back and try wiping. Start fresh and see if things don't improve.
NOTE 2: It'll take awhile for everything to settle down. Especially after installing gapps and syncing accounts. Give it a few minutes to settle and reboot a couple times. The system will speed up after that.
Build 1/17: CM7.2RC0-LW690-BobZhome-011712.zip MD5checksum= 5d093b7a1d580b11e7fa8b9e5bafc95c
Custom Gapps(with old version of market): gapps-gb-20110613-BobZhome-v2.zip MD5checksum= 336211d87495e440e46e6d1f5b37d4d7
Latest Gapps: gapps-gb-20110828-signed.zip MD5checksum= 1647897d8ac3efb04723d2ad2c361a3f
PlayfulGod's ClockworkMod Recovery: recovery.img
Helpful Tips
Overclocking is available in Settings --> CyanogenMod settings --> Performance --> CPU settings. Tweak it as you like, but know this: not all OC's were created equally.
Builders Notes
All credit goes to Blarf(the Dev)...please donate to his beer fund!
How Can You Help?
Please don't thank me, instead donate to Blarf for all the great work he has done.
Enjoy!
Builder: BobZhome
- Alex Zepeda a.k.a Blarf - For his great skills on developing for the Android.
- Koushik Dutta a.k.a Koush - For his bad-ass recover.
- Steve Kondik a.k.a Cyanogen - Seriously? Do I need to state why we owe thanks to this guy?
- PlayfulGod - For help with getting need files and his CWM recovery for this phone
What Does Not work?
- Probably MMS
1-17-12:
- sync'd up with CM: Now with Holo style lock rings(look great with ICS theme)
To enable: Settings > CyanogenMod settings > Lockscreen > Style options > Ring-Lock style > Holo style - Fixed: Charging while powered off
Note: To turn on phone while it is plugged in, just hold the power button until you see the first LG screen - Added: Center Clock tweaks The clock is defaulted to black, which is the same as status bar, so you won't see it. To change the color of the clock go to: Setting > CyanogenMod settings > Interface > Status bar tweaks > Clock color
- Added: ADB Over Network To turn on go to Settings > Applications > Development. Once enabled, go to Settings > Wireless and network settings > WiFi settings then press your menu key and select Advanced. Use the IP address listed and add port 5000 to use ADB via WiFi, ie: adb connect 192.168.1.1:5555 (replace IP address with your phone's)
- Kernel v8: To many changes to be listed
12-2-11:
- sync'd up with CM: Now at CM 7.2.0 RC0
- Added: Custom carrier label *See Screenshots here
- Changed: Camera permissions
- Changed: System Font to Roboto
- Kernel v7: To many changes to be listed
10-17-11:
- sync'd up with CM: CM 7.1.0.1
- sync'd up with CM: SemcRIL: Improve AID selection
- sync'd up with CM: Camera Scene Mode NPE Fix
- sync'd up with CM: RingLock - Fix animation & added arrows to pressed ring bubbles to indicate selection
- sync'd up with CM: audioflinger - Allow bundling the A2DP interface
- sync'd up with CM: Fix setting connection status when switching profiles via 3rd party apps
- sync'd up with CM: libcameraservice - Workaround for nvidia TTF bug
- sync'd up with CM: Updated versions of Superuser & su
- Tweak: GPS - more detailed conf file
- Tweak: Wired Headset - working controls
- Tweak: Camera - Fixed: Touch to focus
- Tweak: Camera - support image/video stabilization
- Removed: Darktremor Apps2SD
09-30-11:
- sync'd up with CM: CM 7.1.0 FINAL(no longer Release Candidate)
- sync'd up with CM: Android version - Updated to 2.3.7
- sync'd up with CM: SuperUser - Updated to version 3
- sync'd up with CM: New Ring Lockscreen style
- Tweak: Accelerometer - reverting SensorDevice class to 2.3.2 state(by mik9)
- Tweak: Camera - Increased picture output size
- Kernel v6: Replaced Smartass and Interactive governors with Smartass2 and InteractiveX governors
- Kernel v6: Added: CIFS(Common Internet File System) module
- Removed: Adobe Flash Player for ARM6 hack
- Removed: MMS hack - Going to work on getting it to work correctly
09-16-2011:
- Sync'd up with CM
- Added: Adobe Flash Player Hack for ARM6 - Not perfect, but it works.
- Kernel v5: a)Fixed: Camera - Invert Issue b)Added: One more OverClocking scale
09-08-2011:
- Added Darktremor Apps2SD version 2.7.5.2: forgot to add to last build
- Kernel v4: a)Optimized b)Changed video drivers
09-05-2011:
- Fixed: WiFi
- Kernel v3: a)Fixed: Overclocking scaling b)Changed: video drivers
09-04-2011:
- Sync'd up with CM(a few days back)
- Fixed: Camera's geo tagging - Thank to Blarf
- Removed Market from build(grab custom Gapps from download area(below), if you want the old market)
- Kernel v2: a)Added: Over Clocking b)Added: Interactive and Smartass governors c)Removed: No physical keyboard d)Switch: to TCP-Westwood
08-22-2011:
- Sync'd up with CM
- Fixed: MMS
- Fixed: BlueTooth
08-17-2011:
- Initial setup of the LW690
- Removed all languages except English
- Removed FM Radio - OV has no radio
- Removed 2 extra themes - theme chooser/manager is still included
- Removed Bootlooder from Reboot/Recovery Menu
- Removed all live wallpaper, but kept live wallpaper chooser
- Removed ADWLauncher
- Added LauncherPro
- Added old Market(I hate the new Windows 7 looking Market) - If you flash Gapps, it will update you to new market
- Added ringtone added: "Somebody's Out There" by one of my favorite bands: "Triumph"
- Changed bootanimation
Download Links
Here is a QR code for a direct download to your phone:
Helpful Tips
Builders Notes
How Can You Help?
Enjoy!
other then that it's sweet.. Thanks for building it!
