Jared631
Member
thank you
It was no problem.
thank you
hello all,
I would like to thank you all for your work and dedication to this thread and for creating and improving the CM port for the LG Vortex. (esp. bobzhome, kappacat , geoffrey, and jacob) My wife has the vortex and has pretty hated every minute of owning it, but we are really unable to purchase something newer and better at this exact moment, so we have had to live with it. I rooted my defy and installed the CM port on there, so i knew CM could vastly improve her experience. anyway long story short, i read thru this entire forum and did some more research and here are the results:
Phone was already rooted, so i followed jacob's youtube guide (part 2) to install the custom recovery. that manual method that he follows, worked perfectly.
installed the newest version of CM that bob created, 7.2.0 or something like that. cam was fine, no rotation, turned off animation, but yes, the call volume was extremely low.
installed the nandbackup from..geoffrey (i think)..whomever had the liquid backups as well...but only used the basic "improved on bob's version". Now, everything appears to work fine, except the animation on the screen lock is a problem. yes, i turned off all animations in the settings. It will come back from the black screen very slowly. I figured out a work around though. I changed the unlock function to use the menu button. That works smoothly and quickly, rather than the screen swipe. If you want further protection, you can disable to screen lock altogether and add a pin code.
now she has a great experience and a lot more memory and resources to work with! thanks all.
now i use it. wifi, 3g signal, camera, rotation, overclock kernel is OK.Okay so I've been quite lazy lately due to a broken wrist. I have uploaded bobs CM7 with all fixes once again. I also have a ROM running liquid settings if any of you are familiar with their ROMs for the HTC Thunderbolt. I swiped some pieces from their Thunderbolt ROM. It's a lil buggy but it does add some nice features, I call it Liquid BobIf someone, especially Kappacat can help make it better that would be awesome. I know for sure it is missing parts.
Bob's CM7 with fixes - Rapidshare
Bob's CM7 with Liquid Settings "Liquid Bob" - Rapidshare
Bob's CM7 with fixes - Mediafire
Bob's CM7 with Liquid Settings "Liquid Bob" - Mediafire
That is the camera bug discussed early in this thread. It is fixed in the best form I've found, which is the 1/19/12 build and GNM kernel. It also fixes a couple other bugs to make everyday use better.
https://sites.google.com/site/bobzhomeroms/vs660
for 1/19/12 build
http://androidforums.com/vortex-all-things-root/307859-gpl-long-last-overclock-your-vortex.html
GNM kernel
Thank you for your response.
I'm already using that kernel, but was using BobZhome-110911.
I just want to make sure, because rereading my description I worded it oddly, but, when I use the AR ap, the camera feed is there with data layered on, but there's two of them one on top and the other on the bottom. In the middle there's no camera, but artifact ed data piling up.
Well, I flash the new ROM and report back. Thank you for the help OhSeven.
VII
