yanngin
Member
yes i did thattt and what happens when yu formatt your sd?did you load CM7 first, then GAPPS second?
you will lose all data that you have in the card itself...yes i did thattt and what happens when yu formatt your sd?
on the guide it said to format for some reason so the OS cm7 was deleted so now its not running? you have link to a back can put on the sd?you will lose all data that you have in the card itself...
where in there can i find a backup rom?
i need a backup tto dowload and put on the sd bc i formated it and everything was erasedd so i need a rom back to load up on CMW and then try to flash CM7did you flash back to stock? if you are, have to do backup again,& start the process again.
i did the flashing again.... how does the boot screeen look like when i flash the latest version?its in Bobs Prepaid, everything you need to load is there. CWM, CM7, GAPPS, & MetrOff. here is instructions that NuttMeg has follow them & you should be alright. http://androidforums.com/ascend-all-things-root/304965-rom-easy-cm7-installation.html
Question about what version I am running. I downloaded and installed Pg's version of CM7 and I know I installed this version. When I check what version is on my phone through the about phone tab it says, it is version 5122011. Why is this, I know I installed the 06242011 version. Just wondering.
By the way I love this version.
you might have had that 0512 on your sdcard a flash the wrong one, delete all the old ones on your sdcard and move new ones on there.
i'm having the same thing, i loaded the latest Bob's version went on about phone & see on Mod version saying CM7 0514. i had PG's 0618 before Bob's.
mines say 07082011, download fresh files and delete the old ones of your sdcard.
DDYW, some ppl just dont realize how much time it takes. Isaac is the one that really put a ton of time in on getting all to work. Just to complie it can take 30min to a couple hours depending on the machine its built on. Setting up a linux vm or installing linux and getting it all setup to dev android in. And then getting the src all together and to build and then to flash, and then get everything to work. And thats working with a repo that had everything you needed, doing it all from scratch, well I'll let you imagine that one lol.
+1 Didn't have any backup except Bob Zhome's 07012011 CM7 build & it showed as CM7 0514,even though I was running 07012011.
1st I'm gettting anxious...I'm used to flashing a ROM every week or two...lol, time for some change and play.
Kolio...Alot talking about it, but since you and I talk the most, I figured this was the best worded one for me to reply.
ALOT of talk about this BobZ ROM !!! I know you went back to 0514 about when I did, and am having very good luck with it (couple SMALL glitches here and there)
Question: Is this BobZ ROM what it's really looking like - A good solid build?
Any chance your could run that Antutu Benchmark and let me know how it's testing out.
Or do you think it's worth just giving a shot? What's the max overclock? Also, are all the Governers Isaac had on there, I'm guessing it's a build off of that or Playful's last?
As I mentioned a few times above/below I don't know??? I am going on Vaca for a week so, don't be surprised if I'm invisible for a week, I'll be down in the Caribbean (Turks and Caicos), and not back till next week sometime.
So, I'm not blowing anything off, just taking a break. I AM taking my PC, BUT, going to try and let it sit....maybe TRY and hit a few emails, but I'm not sure of my internet connectivity there...
SO, worst case tty next week...THANKS, JEFF
Yes, I broken USB mounting with my lastest kernel...will be fixed with this weekends build.I just flashed tha new bob cm7 07082011 all seemed well until i hooked my phone up to my desktop now it doesnt wanna read my phone sumtymes it works and sumtymes it dont any idea's whats going on?And by tha way ive never had this problem before after flashing a new rom til now!
Heres what happened, I clicked on back up current rom, and then clicked ok to the backup name that would be made, then my phone appeared like it was going to begin the process then it didnt. All i got was the white Huawei screen... Now what? My first instinct is to pull the battery but i was hoping for a quick response from someone before i do anything that could make matters worse. Thanks...
