Root [ROM/WIP] - Optimus Prime
WARNING! This ROM is a work in progress! I am not responsible for anything that goes wrong with your phone. You should ALWAYS do a full nandroid backup before doing anything in CWM.
Ok so on to the rom.
What's included:
* aLogcat
* Stock gingerbread SystemUI and framework images
* Holo Launcher (Replaces default launcher)
* Opera Mini (Replaces default web browser)
* Anything else that comes with the phone that I haven't removed
Bugs
* None that I can see right now..let me know if there is anything wrong
What's planned
* PlayfulGod's Plague custom kernel!
* Perfect UI tweaks
* Tweaks to enhance performance on our phones
* Removing more bloat apps
* And more! Give me suggestions!
HOW TO INSTALL
1. Make a FULL backup
2. Format /data once
3. Install the .zip from your sd card
4. Reboot
5. Enjoy! (You may now restore your /data that you backed up)
Credits:
* Me for getting everything together and booting
* Artine: I based my updater-script heavily on his Sleipnir so all credit goes to him for that. All I did was modify it to work for our phone. ;)
* The creators of the included apps
* Anyone else I missed!
Download:
https://dl.dropbox.com/u/8376013/Optimus_Prime_v102_Signed.zip
md5: a32aff6860a828f89d23df3bbe917be2
Changelog:
v1.0.2
* Fixed the wifi issue
* Re-added Opera Mini
* Did a little UI theming. Let me know what you guys think of it.
* Removed some more apps
* Boot animation is back
v1.0.1
* Fixed root
* Added aLogcat
* Stock Gingerbread SystemUI and framework-res images added
* Removed some non-essential apps
v1.0 Initial Release
Enjoy everyone!
Didn't pg's kernal break WiFi? That's why I never flashed it, 'cause I wanted my WiFi to keep working. I might suggest it not be included, but maybe instructions and a link on how-to flash and where to get it. Do you have any screen shots? I'd love to see what it looks like.
Yeah his kernel breaks wifi. I planned on including it if we could fix the wifi issue it has. ;) As for screenshots it doesn't look much different from stock (as of now). I'm going to work on this more tonight so expect an update with some fixes and new additions. :D
hey i downloaded it and flashed it. as soon as it started to do its thing, recovery crashed and rebooted back into recovery. idk, but it wont flash.... followed the instructions and it just crashes recovery everytime... luckily it will reboot back to stock just fine when turning it back on...
That's weird. Did it give any error messages? What version of CWM are you using?
I'm using the cmw in the root and recovery thread.... And i don't recall an error code, but i know that whenever i tried flashing it, the screen crashes and it reboots into recovery...when i rebooted the phone, it went back to the stock ROM
Hm that's weird. I'm going to add an updated rom later tonight (I can't test it during the day). Hopefully some of the issues will be fixed.
I flashed it and it worked but thwn i noticed that not only was wifi bro.ken but data wasn't working either
An updated version is being uploaded to dropbox as I type this. Changelog,
* Fixed root
* Added aLogcat
Wifi still doesn't work. >_< If anyone could figure out what's going wrong I'd really appreciate it.
* Fixed root
* Added aLogcat
Do you still have the kernel in there from Playfulgod?
Still having probs with wifi though? Hmm. I would think that if it's stock you should be able to just use it. I'm not a programmer/developer though and really have no idea how the files interact.
Yeah I've searched google far and wide for a solution but I can't find a single thing.
Uploading the new rom now. Changelog,
v1.0.2
* Did a little UI theming. Let me know what you guys think of it. I'm still getting the hang of theming this system so bear with me. ;)
wifi works off and on with me. sometimes I have to turn off then on for it to work or I will get a message that says no network connection. other than that I love the ROM so far. at first I couldn't get play store to connect. kept getting an error. So I fixed permissions in CWM and everything is great. runs really smooth. just wish PG's kernel was working.
after using this ROM for the past few days I noticed slow downloads even when connected to wifi. I ran a speedtest and I clocked between 400-700 kbps consistently. what can I do to get my wifi speeds to the full capacity. should be 6 mbps at home where I am testing it. thanks for the help.
Flashed it last night and first thing I noticed was there wasn't an app manager. Quickly took care of that with titanium backup because I had a backup of it. Otherwise good so far. Will keep you updated with anything else I find.
