Root [ROM][WIP][Unofficial] CM7 from source|Testing round #3 begins!!
varun.chitre15
Android Expert
****Advanced users only****
Hello everyone, I have built CM7 for our A70 from CyanogenMod sources after lots of changes in the device tree
Test round #2 will begin today probably, the build is around 80mb
I won't be flooding this post with features so as to maintain the cleanliness of it :)
Usually the first build doesn't boot and you might get stuck on the logo, that won't be a problem.
Just get a copy of Android-SDK which is around 358mb from here Android SDK | Android Developers and install it as you may need to run a logcat using that
After the Android-SDK installation, go to your installation dir might be C:/Program Files/Android and shift to the tools folder in it and execute the ddms.bat file in it by double clicking.
Next connect your device using USB and see if the device shows up (Remember, do this as soon as you reboot from recovery so as to collect most of the log)
If your device shows up on it then click on it and In Device tab on the top right, click on Run logcat option.
Before reporting that the device doesn't show on the list first confirm whether it shows on froyo.
The flashing instructions are bit different here
1. Factory reset
2. Format system-->In mounts and storage
3. Format cache
4. Format data
5. Install the cm7 zip
Link: cm-7-20121228-UNOFFICIAL-a70.zip
Test round #3(latest)
Changelog:
Code:
# Added wiperinterface and the missing CKPD daemon
# Fixed the vold incorrect path
# Added a bunch of fixes for RIL which are causing the ROM to stuck on logo(hope it boots)
# Some changes in build.prop to match up with new configuration
# Added some compiler flags so as to match with froyo ROM configuration
# Removed some useless lib files
# Added the OEM BYD wifi bcm4329 drivers and its module
# Initialized the sensord and fmradio service in init
# Manipulated the UMS lunfile path
# Some under the hood fixes
Test round #2
cm-7-20121227-UNOFFICIAL-a70.zip
Changelog for Round #2:
Code:
# Recompiled for qcom hardware
# Target libs and binaries set as qcom
# added appropriate graphical paths
# added wifi chip information
# added bluetooth chip information
# integrated experimental usb fix
# toggled back camera stub
# added missing kernel files in boot.img
# added some proprietary binaries
# few alterations in init
# some other changes in the makefile
# added some missing properties in build.prop
Test round #1
cm-7-20121226-UNOFFICIAL-a70.zip
Varun, I have everything installed but the only problem is I'm using wimdows 8 and the device is not being recognised.....[adb -d devices] is not showing anything..
yeah, i did it....driver is successfully installed but still no adb device...copied the [usb.ini file also]
and, monitor.bat can be used instead of ddms.bat..it says
Its not working even in XP...what is happening? Earlier, i had made it work
what's ddms and logcat, can you please explain?
Second question is that, can we flash this zip using cwm (v4.0.1.5 on which currently a70 works) ?
No, it doesn't starts up.... i waited for 3-5 mins....
I have done the flashing twice but it stops at logo....no activity after that
that logcat was of hybrid v3
thanks buddy!
I'm flashing it using cwm then. (can't really wait to download 350mb android sdk app to test it)
btw, it would be great if you could post some screenies of the rom?
