Root [ROM][WIP][Unofficial] CM7 from source|Testing round #3 begins!!
i think aroma file manager (recovery 1) works on a70... but not sure coz it didnt work properly on my phone as it has that wierd problem with touch(reversed mirrored touch)... touch was concentrated at a single point but was working...
dont know if ths will help... some1 try it on ur phone...
Can you reconfirm?
EDIT: No that's not true, even if you think it is working, it is not working because it is thinking gsensor as touchscreen. Just try tilting your device here and there, you can see the flickering.
ok ok... i thought touch wasnt working coz of my touch problem... didnt knew abt gsensor thing... and yeah it was flickering... but i dont have my device right now to test it,trying to get a new touchscreen...
I have compiled CWM 6.0.2.7 non touch version and it is so so superfast!!!!!!!!!
Backup of CWM5 = 3min 12s
Backup of CWM6 = 1min 2sec!!
Also there many new handy features in v6
But there is a old problem, USB not getting detected. Even if I integrate the usb fix I made. I am working on new fix.
I will release both CWM6 and CWM5(completely bugfree I.e USB,ADB fixed and clean!) tomorrow.
But still touch isnt working???
we gotta simply flash it??this flashable zip..
ok flashed it but there's no 'Clear battery stats' option in this new version
Yes ... why it missing from cwm v6? So i have to replace it with battery calibration.apk (free from play store)
Sent from my movi m1 using Tapatalk 2
No not a dead end
Good news!!
I have successfully compiled ext4 module and it loads successfully :D
I am excited to see how it performs when I set it as default filesystem :D :D
I will release the new boot.img with ext4 support in 2 days :D
Working on TUN and SWAP support now :D
Another succees
TUN compiled and loaded
Now VPN works :D :D :D
Check the screenshots :D
great work man was inactive fr a long time just visited and saw ur progress on cm7
keep up the good work
waitn fr ur stable release with touch screen workin
lets hope u find the rt drivers fr touchscreen
