Root [ROM][WIP][Unofficial] CM7 from source|Testing round #3 begins!!
thanks buddy!
I'm flashing it using cwm then. (can't really wait to download 350mb android sdk app to test it)
btw, it would be great if you could post some screenies of the rom?
No screenies dude.
This is ROM built from source and is not favourable for daily use as its in very early stage and is going to take lots of time to debug as not many testers/dev are here to test or report faster.
Round #2, link on first post
Changelog:
Code:
# Recompiled for qcom hardware
# Target libs and binaries set as qcom
# added appropriate graphical paths
# added wifi chip information
# added bluetooth chip information
# integrated experimental usb fix
# toggled back camera stub
# added missing kernel files in boot.img
# added some proprietary binaries
# few alterations in init
# some other changes in the makefile
Waiting for the reports
See if it boots or usb gets detected :)
Downloading....! speed is kinda slow....i m only getting about 60KB/s
Done...!
Adb is now working....the device shows up....but still stuck on micromax logo
Here are some files....
this forum only support .zip file.. not even log file
  • event.zip
    event.zip
Done...!
Omg that's a big success of mine....yayyy!!!!
No one can stop us from cm7 now!!!
Get me a longer logcat
Use d-h.st to upload files!!
We will start the round 3 today evening!! itself :)
Added some missing stuff and some hotfixes so as to make CM7 boot :)
Lets hope it boots this time :)
Changelog:
Code:
# Added wiperinterface and the missing CKPD daemon
# Fixed the vold incorrect path
# Added a bunch of fixes for RIL which are causing the ROM to stuck on logo(hope it boots)
# Some changes in build.prop to match up with new configuration
# Added some compiler flags so as to match with froyo ROM configuration
# Removed some useless lib files
# Added the OEM BYD wifi bcm4329 drivers and its module
# Initialized the sensord and fmradio service in init
# Manipulated the UMS lunfile path
# Some under the hood fixes
Awaiting reports
Link on 1st post!
If it doesn't boot get a logcat, dmesg :)
Btw in few posts before u posted a screenshot with a70 connected with ddms with its serial no
Was the serial number same as froyo?
stuck on boot
https://www.dropbox.com/s/y9e96nbtvbxqm5i/dmesg2.txt
https://www.dropbox.com/s/e8kvtpv4ovoampc/cat2.txt
https://www.dropbox.com/s/1soxq0spidn0bzm/log2.txt
i got no changes in d serial no. 1234567890abcdef ,same as tht of round 2...
for stock dis no. was different ,some bd.... something....
Alright,
From the logcat I can see that
1. Vold(sdcard) is fixed
2. The sensor binary is working too.
3. Ckpd daemon got initialized as well
Tomorrow on round 4 I will give a small flashable zip fix instead of whole ROM.
CM7 has done progress. The ROM doesn't boot because the network drivers are somewhat messed up. I used froyo drivers in them. Tomorrow will freshly compile the libs from cm7 source itself.
Will also try to get a copy of ROM for myself.
Damn! Got a corrupted zip even the second time :crying:
