chosendude
Member
So i love that my phone is rooted, but i also love a great battery even more. So what i am wondering is, what do you feel is the ROM with the best battery life with what kernel.
Thanks.
Thanks.
http://androidforums.com/droid-roms...oyo-2-2-1-fast-stable-great-battery-life.html
I'm a little biased, but i believe this ROM takes the cake!
Everyone here is giving their own opinion - but you have asked a very subjective question.
battery life is going to differ due to many different factors - your usage, your background services that actively run for monitoring things (like Locale), how hard the phone has to work to access towers, whether you are using BT or not (and if it is on and trying to connect), whether you use WiFi or not and if it is on and scanning, that apps that you use themselves, the brightness of your screen when in use, and so many other factors.
It is best if *you* check out what works for you.
