Root [ROM] (Working) (Tested) Silverlight_4.0 for Micromax A75
[FONT=&quot] SilverLight[/FONT][FONT=&quot]
In the Above Rom three things i don't liked
1) Network Icons & Data Connection icons Are not Good
2) Battery Stats is for 5% interval
3) No indication of the battery % at the time of Charging.
Changes Made by me..!
1) Changed Network Icons to New Icons :p
2) Now battery Stats are for 1% indication :p
3) While charging now you can look how much it is charged through hybrid animation of charging ;)
For all this you have to flash the following file.. :D
No need to wipe data or factory reset... :p
first flash this..!
Link: Download spice_silverlite_network&battery.zip from Sendspace.com - send big files the easy way
Then Flash this..!
Link: Download spice_silverlite_New_icons_emotions.zip from Sendspace.com - send big files the easy way
Don't Mismatch the Sequence... :mad:
ScreenShots:
links: Download 2012-06-23-23-38-57-283_final.jpg from Sendspace.com - send big files the easy way
Good Luck..!
:D
[FONT=&quot]Steps To Install :
[/FONT]
[FONT=&quot] ****(Important) Flash [/FONT][FONT=&quot]A75v3@ADProgrammer[/FONT] from Here ... http://androidforums.com/a75-all-things-root/555634-rom-a75v3-adprogrammer-flashable-reloaded.html ****
Bro whenever you refer to a [ROM], [APK] or [TUT] in a thread, Always add the credits with the original developer name inside your post... most probably right after the reference. It's not a rule though, but it helps you earn more Kudos and more respect in everyone's mind.... :D :D
Ohh..... I dont Know how i forgot to add but so sorry for that :confused:
I am adding..! :(
****(Important) Flash [/FONT][/COLOR][FONT=&quot]A75v3@ADProgrammer[/FONT][FONT=&quot] first from Here ... http://androidforums.com/a75-all-things-root/555634-rom-a75v3-adprogrammer-flashable-reloaded.html
Hey Aayush is it necessary to Flash ADV3 first and then Silverlight 4 y cant we directly install it as when checking internal memory its only 57mb left and I have many more things to install. And haan Aayush check app2sd and decide if we need this or link2sd is fine and try to port ext3 or ext4 if possible as read somewhere ext4 is fast and smooth.
I dont know whether it is important or not but this procedure is given by the rinoxos who modded this on Mito 898 (similar to Micromax A75).. :p
But My question is this why to take risk just Flash ADP A75 V3 Reloaded and Then Flash This ROM.. :rolleyes:
Take care :)
please take a complete nandroid backup before you do anything..!
Just check Camera are Working :p Front camera ? are Working When u capture it. And with rear turn on the Flash And Capture in dark Area :p pls Check it :D
Dear DarkGOD,
I have tested the Camera App Seriously..:D
I have not found any Bug yet, Back Camera Working Fine, Front Camera Working Fine, Even Front Camera Working for the 3G video calling from the Dialer.:D :)
I have taken the pics choosing the 5 MP mode and 3.2 MP of the camera What i found is that Quality of Both while looking is same but the file size of 5 MP picture is More than that of 3.2 MP :rolleyes:
Barcode scanner dont works (It was also not working on the stock Rom) it might be due to the insufficient camera capabilities... :o
I forgot to mention about Camera Flash..
Camera Flash is working fine no problem at all.. :)
I have clicked more than 50 pics in past two days not a single time the camera app is crashed.. :D
List of Applications are not working in Silverlight _ 4.0..
1) MobileUncle tools (Not Doing Anythings :()
2) A2SD GUI (I tried using it but not doing anything dont know why i think i dont know how to operate it.. :D)
I have deleted the following apps..
1) Sony launcher (Actually this launcher dont have any bug but i dont need 2 launchers i liked ICS launcher more .. :) ;))
2) MobileUncle Tools (Not Working)
3) A2SD GUI
Currently i have installed Root explorer (Preinstalled File explorer is not upto that mark :() and Link to SD (Working well.. ! :D)
Well but i had some Camera Bug in Silver light.. and i doesn't Why u using A75v3@ADProgrammer as base :D its similar To stock itself
I abt a2sd GUI U had used Mito or mmx boot.img may some changes in kernel Get
original Sliver-light ROM And Flash it... (i mean Spice boot.img)..
I i got it..! :)
I'll try now..
Please if you are on the SilverLight 4 Please can you tell me that IS WIFI Working..! :confused:
(But Wifi Hotspot or Wifi Tethering is working well ... :p)
My Wifi is Not Working just tested 5 min before, Tried static IP settings but still not connected.. :(
I think this is a similar problem may be fixed after flashing original spice boot.img :confused:
If its not Working with you then i'll post the bug in Original Post.. :(
@darkgod the camera was not working in original silverlight rom
but it was working fine in modded silverlight rom provided here in op
becoz spice mi350n has autofocus
strange bug I flashed silverlight rom but I am unable to attain root
permission every app says "ur device is not rooted"
@pkotenetwork open Root explorer navigate to bin Copy netd to system/bin
and libhardwarelegacy.so system/lib (take Those files form Stock ROM)
and go to system/etc copy whole Firmware folder from stock to Spice or which u had installed in your Phone be Sure To give Correct Permission With Root explorer If u messed U will be Boot Looped.. Should Not blame me :p
if u trying to Port .This May be USeful Guide To port
@saivignesh i had that modded ROM only i had same Camera problem :o
I think the ROM making diff prob for diff mobile lol :D
install ROM manage And Give Fix permission i think SU had lost its Permissions ;)
... Brilliant ROM ... :) ... softer than a CottonCandy ... just love the way i handle my phone more and more after this flash ... Thank you so much for making it live on my phone ... may be for much longer time ... ;p ....
... well I'm much into customizations and screen looks ... Theme guy ... which i miss in Sony Ericsson home ... any fix to the Theme stuff ... can it be themed ... !!! ... well, will await and try Googling on my own ... just One thing to it and ya rocked my phone ... juz love it ... Thanks ..... :)
one more bug it is not searching for all the available network operator
I am not able to use airtel
I think I first got to install that ad rom
I'll do it and Let you know..! :)
Thank you..! :p
I am too not sure whether A75v3@ADProgrammer is really needed or not but its not as that of Stock rom its notification toolbar differs from stock rom. :)
For Finding whether A75v3@ADProgrammer really needed or not i'll flash Silverlight After Stock Rom again and i'll let all you know.. ;)
Up til i test it please others Flash this rom as it is directed..! :rolleyes:
Thank you..!
