Root [ROM] (Working) (Tested) Silverlight_4.0 for Micromax A75
I was just stupid for the last 2days
I just kept installing the original silverlight rom with different names
noweverything is fine
awesome rom for a75
display was better now coz of bravia engine
can anyone confirm the beats audio?
Low internal memory is result of deodexed rom...dalvik cache of every syatem app n framework files will eat up ur internal memory n leaving u with 50 only..
If somehow we can repartition the nand flash n make system partition small then we can compensate for dalvik cache data files.
Another option is data2ext which is being claimed to work now on A75 n probably on this same rom..giving u internal memory according to ur 2nd sd partition.
[FONT=&quot] [FONT=&quot]
****(Important) Flash [/FONT]
[FONT=&quot]A75v3@ADProgrammer[/FONT][FONT=&quot] first from Here ... http://androidforums.com/a75-all-things-root/555634-rom-a75v3-adprogrammer-flashable-reloaded.html **** (Thanks to Aayush)
Thanks for the ROM. it is butter smooth.
BTW I don't think adprogrammers rom is a pre-req.
From your steps it is clear that your clearing /data , /cache and /sd-ext ( factory reset ). if you see update script it is formatting /system . So clearly nothing leftover from previous images. So bottom line is you can upgrade to silverlight from any ROM.
Any other thoughts on this ?
Thanks Again:smokingsomb:
Hey Maastermind1024 i have got the internal memory of 1GB on ICS v1.0 by sagarwep and i also think its because of the data2ext i dint tried it on any other ROM so user can try it n btw this ROM doesnt left with 50MB it has more than 115MB for me when i installed it. you might have got confused between silverlight and ICS v1.0.
Sorry bro...too much of rom coming day by day...got confused between those 2.
N if u can provide that data2ext script or preferably whole init.d folder then i can also try that on other roms,it will be great if it work out of the box.
This rom works great! got only one real issue with this rom wifi is not working. please give me a fix for that, thanks in advance.
I am unable to send Video files through Bluetooth, Whenever I sending Video files, the other mobile not getting the message to accept the files, but this problem is not coming when I am sending the audio files. Please Help
Definitely the fastest rom.
The only things that bugs me is
Its mentioned spice mi350 in model number in settings
N the background color which is grey such makes It difficult to read at some places
anyone know the way to fix tethering
Hi all,
Facing USB Tethering issue..? :confused:
Actually i am not facing any USB Tethering Issue for me USB tethering is working (means Connecting to PC for Internet) but i am not getting any data (means i am not able to browse anything) i dont know why this is happening.. :confused:
Just for Now all others facing This issue try Easytether.apk app or PDAnet.apk app for USB tethering its also available free on google play or just google it..!
Its working fine (I am using right now.. :))
This may Help you..! :)
N another thing
It had reduced my inbuilt memory!!!
Yes it Quite true..!
Internal Memory of Silverlight ROM is very low we get around 50 MB internal Memory only.. :(
As said by mastermind its a deodexed rom thats why we dont get Much Internal Memory..
Use Link to SD to move your apps to SD Card will help you to save some internal Memory (Please dont ever try to move your system Apps to SD card :p)
please and please give a wifi/hotspot fix for this rom
My Wifi Still not Fixed i tried lot of things but nothing worked yet.. I'll let all you know once it is fixed..
My Wifi Hotspot is actually working but problem is that i am not able to fetch any data through it..(Means No Browsing and Downloading :( )
Use Easytether.apk or pdanet for Tethering via USB it works..!
I am Using Right now..! :)
At the Very first Time i was also facing this problem but now i dont have any problem with Bluetooth do this.
First Reboot your device and Pair Your Device before sending anything and then send the file it will not cause any error or any problem to you..
This may help you..
Best Luck.. :)
Actually if you gone through both ROMs you'll find some similarities that both having the same Notification tool bar and settings.apk its not the same like MMX stock rom this may be the reason for choosing ADP V3 as a base rom for Silverlight.
Clearing Data and Cache will not erase your system.img, it will be removed after flashing other ROM.
Factory Reset or Clearing Data/cache will erase your Data.img
So Thats why rinoxos modded it for Mitto 898 (similar to Micromax A75) he telled to must have ADP V3 Before Flashing Silverlight..!
That is all what i think.. :)
I flashed it without ADP V3 had flashed it on stock also no harm you can just flash the silverlight 4.0 on any ROM it doesnt matter as i have done this but its totally upto u so think and decide...
This ROM is perfect & Stable for this device. Once you have flashed Masterminds recovery than you can flash any rom. the only thing is that you must wipe/factory rest and clear dalvik after that flash ROM.
no problem yet.
