My Wifi Still not Fixed i tried lot of things but nothing worked yet.. I'll let all you know once it is fixed..
My Wifi Hotspot is actually working but problem is that i am not able to fetch any data through it..(Means No Browsing and Downloading)
Use Easytether.apk or pdanet for Tethering via USB it works..!
I am Using Right now..!![]()
theme manager?
When can we expect next version of silverlight? Any Ideas???
Actually if you gone through both ROMs you'll find some similarities that both having the same Notification tool bar and settings.apk its not the same like MMX stock rom this may be the reason for choosing ADP V3 as a base rom for Silverlight.
Clearing Data and Cache will not erase your system.img, it will be removed after flashing other ROM.
Factory Reset or Clearing Data/cache will erase your Data.img
So Thats why rinoxos modded it for Mitto 898 (similar to Micromax A75) he telled to must have ADP V3 Before Flashing Silverlight..!
That is all what i think..![]()
one issue:
unable to find all contacts in contacts but i can see contacts in phone app what to do?![]()
pls can you tell how to edit toolbar icons????I have used Some ICS Toolbar icons..
Just Try if u like it..!
Flash it similarly to Previous post..!
Screenshot:
Link: Download 2012-06-23-23-38-57-283_final.jpg from Sendspace.com - send big files the easy way
Download Link:
Link: Download spice_silverlite_New_StatusBar_ICons.zip from Sendspace.com - send big files the easy way
Enjoy..![]()
