Roms for galaxy s2
Can anyone suggest a good rom to flash on a galaxy s2 (SPH-D710BST/GC01)
It depends on what you like and or want in a Rom. I would also just cruise the All things Root front page and check out the many threads on Roms.
Lots of reviews, with pic's included!!:)
touched by s4 is my 2c. but what works for me may not be suitable for you. theres no shortage of roms. took me about a month to decide honestly, not exagerrating, but im picky and do research before i flash anything to my phone
If i may recommend one, i personnelly enjoy the gc01 flash able zip deodex and debloated with the 4.1 to 4.2 transformation pack. Works well and does simple everyday tasks. Also the aio 4.0 mod works vary will with it adds tons of nitfy features. :D but as the above guy has said what works for me may not be what you enjoy. I've been threw lists of ROMs and found revolt to be pretty good thou some apps keep dissapearing when i installed a new one (?) Not sure if this is a bug in the kernel or what. I came from the prevail with hoarks13 cm7 which was a lot simpler to flash and do what ever i needed but i do enjoy this phone as well. Good luck and may the flash be with you
