Nwilson1605
OK... now that rooting is succeeded... Anyone find working ROMs?
OK... now that rooting is succeeded... Anyone find working ROMs?![]()
adb device
adb shell
su
cat /proc/mtd
I tried using the "Terminal Emulator" application to enter the first command in your list and my response was "permission denied" could this be a root isssue?
Here is the results using terminal emulator, please let me know if I messed up which I think i did...
$ export PATH=/data/local/bin:$PATH
$ adb device
adb: permission denied
$ su command
# adb device
adb: not found
# adb shell
adb: not found
# su
# cat /proc/mtd
dev: size erasesize name
mtd0: 00500000 00020000 "boot"
mtd1: 04100000 00020000 "cache"
mtd2: 00700000 00020000 "recovery"
mtd3: 00140000 00020000 "splash"
mtd4: 00100000 00020000 "FOTA"
mtd5: 00700000 00020000 "FOTA_STO"
mtd6: 0aa00000 00020000 "system"
mtd7: 0d520000 00020000 "userdata"
mtd8: 00080000 00020000 "misc"
mtd9: 00180000 00020000 "persist"
adb devices
you have no reason to worry ..
not possible in many devices !! but yes in urs
I also have a rooted lgl45c (via unlockroot.exe) however I havent been able to find any confirmed working and (or) beta roms. If you need any additional help grabbing any info to start building let me know if I can help get it off the ground. Eager to see some cyanogen stuff first hand.
Dev: size erasesize name
mtd6: 00aa00000 00020000 "system"
Thanks for the info
But we already have it
here is what we need now ...
Now to ease out the task i have made a .bat file for you ...
* extract the stuff I have sent you in any place
* you will find a folder named "files" and another file called "run_me.bat"
just connect the phone in Debugging mode
make sure you have least 600 Mb of free space on your sd-card ..
* just double click on "run_me.bat"
* it will do its task
Now your device will Restart <-- Do not worry i have said him so
* this is a very big thing to do hence it will require least 13-14 Mins
* Be patient ..
* Your device is extremely safeyou have no reason to worry ..
* Now once the software says "Done"
* you will have a folder called "images" in your SD-Card
* Just send me the entire folder.. It will have contents like boot.img system.img etc
NOTE : I have not configured ur phone to provide a copy of data . My intentions are never bad
the images are of the other partitions which have content like system , boot, recovery etc and NOT of your user data !!
always remember never give ANY ONE on with your userdata dump
it may contain your passwords and other stuff
Now you will find a folder inside your sd-card named "device-images"
send me that folder in-fact upload to " mediafire.com " and save for everyones benefit
the folder will be huge ...
you can use 7z utility to compress the folder and then upload it ...
The utilities are here :
Hey !!
Its all done
I got the stock Dump ,also a ROM is already developed..
I will post back Soon![]()
Hi,ninadchaudhari,
what about LG P698f (LG Optimus Net Dual) ?
Is this the same phone ?? (NO)
I did not get a single thing
Can you plz elaborate ?
